ManBearPig
It makes sense that the torque spec follows the stud so the spacer should be torqued to the hub at the factory 150 ft/lbs. Will these little lugnuts provided take that much, though?
If the torque spec is based on stud size and thread pitch, why are the coyote brand spacers only supposed to be torqued to 90 ft/lbs when they are the same size as the factory studs? Are they poor quality? Is there a particular brand that is known to be better than others?
