Boost Works Twin Turbo Systems Development
Our friends at Boost Works have been hard at work developing several new twin turbo systems for the S550 Mustang and they’ve previewed the design and development on our forums.
Since Mustang owners are a diverse bunch with diverse needs and budgets, Boost Works will be offering both entry-level and top-tier kits that are tailored to the goals of each S550 owner.
The Katy, Texas based company plans for its entry level turbo system to be capable of making 800 to 1200 horsepower using Precision Turbo billet wheel journal bearing turbos using factory stainless tubular manifolds and fabricated stainless mid-pipes to hold the turbochargers and waste gates.
The top tier system will feature Comp Triplex ceramic ball bearing, billet wheel turbos. These unique turbos do not require engine oil, and instead rely on military grade turbine grease to keep them lubricated — a design that eliminates the need to use scavenge pumps or tap your oil pan. The top level option also features 4-1 tubular turbo manifolds, hand crafted from 316L stainless steel. You can also rest easy knowing the turbo manifolds will come with a lifetime warranty against cracking.
All of the above combine for a top tier turbo kit that will be capable of supporting between 800 to 1600 horsepower depending on the turbo sizing which of course, will be custom tailored by Boost Works to meet the goals of each S550 owner.
See the development updates of the Boost Works twin turbo systems for the S550 Mustang in the forums.
