The Mustang world is filled with modifications you did not know you wanted until you saw it on a fellow owner’s vehicle. Such is the satin black heat extractor hood insert from Scott Drake.
Designed for the 2015-2016 Mustang GT, these laser-cut honeycomb mesh grilles come with removable backing plates and allow the OEM hood vents in your S550 Mustang GT to do its job while adding a more aggressive, race-inspired styling to the hood. The heat extractor hood inserts also mount directly into the S550’s factory locations which means no drilling or cutting is required.
See the Scott Drake heat extractor hood insert installed on M6G member smittybat’s Triple Yellow 2015 Mustang GT and also check out CJ Pony Parts installation video in the forums.
