BMR Suspension Caster Camber Plates
If you have a lowered S550 Mustang the factory alignment adjustability may be insufficient for your needs.
The good news is you can add caster and camber adjustability and fix alignment issues on your lowered S550 with these new Caster/Camber Plates (CP001) from BMR Suspension.
The CP001 Caster/Camber Plates are manufactured from CNC, laser-cut steel plate and a 100% bolt-on kit designed for street performance, drag racing and handling applications, giving S550 owners the ability to correct the alignment on lowered Mustangs and add aggressive alignment settings for both street and track.
In addition, BMR replaces the weak factory strut mount bushing with high-quality US-made, Teflon-lined spherical bearings.
Check out BMR Suspension CP001 Caster Camber Plates in the forums.
