Our friends at aFe Power have been busy developing an all-new roto-molded sealed cold air intake for the 5.0L Coyote V8.
The “Momentum GT” intake kit is a one-piece air box and tube is constructed out of Thermoset plastic to resist heat soak and was designed around a large filter to allow for maximum airflow and filtration — providing the option of choosing the high flowing Pro 5R or the easy to clean Pro Dry S filters.
Beyond performance, the intake was also designed for functionality and looks — incorporating a large clear window to easily check if the filter requires maintenance.
aFe Power has ensured a perfect fit utilizing the factory mount points and using 3 billet aluminum CNC machined fittings for a proper seal with the factory vacuum lines.
Check out the full technical details in the forums.
