BugsOli
Hello everyone, I'm opening yet another alignment thread as I went back to my stock suspension in order to pass the yearly inspection here in Belgium (yes they are that stupid regarding mods here, if they are not installed by a proper shop with all the homologated papers )
The context: I have a manual European Ecoboost Premium, which if I recall correctly has some of the Performance Package installed (basically all European Mustangs have the Performance Package, or part of it, such as suspension and bigger brakes).
Last week I went back to the stock coils from the Eibach Pro-Kit (installed by myself last year) as I had to pass the yearly inspection here in Belgium.
While installing the stock coils in the rear, I installed the Steeda Alignment dowels at the same time, to make sure my rear was centered.
Inspection went flawlessly, passed in under 20 minutes, which means I'm good for one more year (yeah it's a yearly thing).
After inspection, I went to a tire shop to do an alignment because I wanted to make sure everything was good and I wanted to reclock my steering wheel properly (it was a little bit to the left when the front wheels were straight, and I hated it)
Since the alignment, the ride is WAYYYYYY worse: the steering wheel is now straight but when driving I feel like my rear wants to go its own way, it's a weird feeling, especially when I turn I feel like the rear is much more "snappy" and wants to oversteer! It's like the car body is not straight even though the front tires are straight... I feel it in the driver seat, but I can't see it when facing the car....
Here are the numbers I got after the alignment, the guy did the measurements with his database but did not select the Performance Package, therefore I think he messed up badly:
FRONT CAMBER
FRONT CASTER
FRONT TOE
REAR CAMBER
REAR TOE
I believe these numbers are not good at all when looking at the BMR numbers or even Ford's own numbers.... everything is closed here tomorrow for Easter therefore I need to wait until Tuesday to go back to the shop and complain...
I would appreciate all the input I can get here guys...
FRONT CAMBER
LEFT | RIGHT |
-1.06° | -1.15° |
FRONT CASTER
LEFT | RIGHT |
6.53° | 6.53° |
FRONT TOE
LEFT | RIGHT |
0.00° | 0.00° |
REAR CAMBER
LEFT | RIGHT |
-1.52° | -2.00° |
REAR TOE
LEFT | RIGHT |
0.07° | 0.06° |
