sigintel
- Nov 24, 2015
- Republic of Texas, God's Country
- Ray
- 2018 GT
That knock limiting might be saving your motor currently. You are on lower octane and have a real heat problem and the tune is pulling power to save the motor from detonation death. (+1 Whipple failsafe tune)
Hold off on running it hard till you are sure that IC pump is all good and any other issues.
If you have Reische 170, on flat highway you should be 185-205CHT MAX after 15 min warm up and 10 minutes highway flat.
Any flat highway near you? Where you at in CO? (Used to live Louisville, Eagle,Durango: flat highway can be hard to come by soemtimes..).
When you start the car, can you see turbulence in the IC coolant level/fill port?
This is indication of IC pump running.
If you open the IC fill neck while the pump is running, you can ruin your paint by hosing coolant all over; maybe have hose ready to wash off just in case?
Also, there are advantages to using the Ford Motorcraftt orange prediluted: namely its been durability tested for metal passivation/corrosion, head gasket metallurgy, water pump seals, lower system pressure per temperature, etc.
