Jon|3.7
- Jun 21, 2015
- Houston, Tx
- 15' 3.7 Mustang
not sure what happened here, but i like my steeda progressives
daily driver.
daily driver.
Perfect ride quality for a daily driver! Thank you!not sure what happened here, but i like my steeda progressives
daily driver.
Well, this response just told me which springs will be going on my car, and they won't be coming from Pompano Beach. I clearly read this as "I don't know how to answer you, so here's a smart ass response"...:rant:I would contact a spring engineer so you can understand our table.
Or, you can call our engineering dept. at 1800 950 0774 to discuss, they will be able to explain the table in greater depth.
On another note, provide your data for the rear GT350 .
Really? That's what you got out of that? My bet is you're a fan boi and it didn't change a decision for you if that's what you got from that reply. Either that or you weren't following the whole conversation.Well, this response just told me which springs will be going on my car, and they won't be coming from Pompano Beach. I clearly read this as "I don't know how to answer you, so here's a smart ass response"...:rant:
Fan boi eh?Really? That's what you got out of that? My bet is you're a fan boi and it didn't change a decision for you if that's what you got from that reply. Either that or you weren't following the whole conversation.
Because I hadn't made any other comments, i'm a "fan boi"? Not that I feel the need to explain myself to you, but I follow a lot of posts on here, mainly to get more information, but also to chime in from time to time. I felt the need to chime in on this one because information was asked, provided by another, and then when the validity of it was asked to be clarified, it turned into a pissing contest.Really? That's what you got out of that? My bet is you're a fan boi and it didn't change a decision for you if that's what you got from that reply. Either that or you weren't following the whole conversation.
Huh? Maybe I missed an edit, but the rate column shows 212 (4x53), and subtracting the two loads shows 211. That's pretty close I'd say.[MENTION=25806]SteedaTech[/MENTION]
You are claiming 265 as the rate when compressing the Front spring from 9.108" to 8.108" - but your load goes from 413lbs to 624lbs.
Correct me if I am wrong, but isn't that 211lbs required to compress the spring 1"?
I've calculated that there is approximately 850 lbs of sprung mass on each strut, with a motion ratio of ~1:1, so the curb/installed height would be very close to the 7.108" point. It's quite linear rate from every point beyond that approaching solid height. Thanks!View attachment 113199
Here are the numbers. No twisted propaganda please. We tested every 1/4 inch where others tested every 1/2 inch.
I noticed you edited - Thank you for fixing your data.I would contact a spring engineer so you can understand our table.
Kelly, the point I was making is that the front springs of GT350 are Linear and the rear are progressive. Both tables represent that. Which you disagree and got off topic.I noticed you edited - Thank you for fixing your data.
That is all I asked for. There was no need to respond in that manner.
I will be showing data soon enough, no worries. :cheers:
Thank you for clarifying.Kelly, the point I was making is that the front springs of GT350 are Linear and the rear are progressive. Both tables represent that. Which you disagree and got off topic.
The reason I responded that way, is your always taking meaningless shots at Steeda and their customers.
Again, I always want to work in a professional manor, and you can contact our engineering dept anytime to collaborate on OE concerns.
The Best,
Mike D
Let's respect our customers and colleagues, agreed!Thank you for clarifying.
In bold, I would not say that is 100% the case.
You, Steeda, are as guilty as myself or other companies. Let's not throw stones my friend. I want to keep this as civil as possible. I have a whole folder full of quotes, pictures AND proof of something specific - you do not want to go there.
Back on topic. I claimed that Ford doesn't use a "truly" progressive spring set-up. You have provided some solid data to show the progression of the spring deflection when compressed. My post picking apart your data was uncalled for - as it does not relate to what we are discussing - I apologize.
I will provide solid data soon as well. :cheers:
