weld rst s71
jared89
NE PA
2015 mustang gt pp
I want to get these for the rear for some drag radials. From what i read i need 17's for rear? No website list them as fitting the 2015's. Could someone tell me what ones exactly i need.
jared89
NE PA
2015 mustang gt pp
thanks:cheers: I just messaged them, they said it is like a 4 week wait:frusty:.
esacteksab
CO & KS
2015 Mustang GT
All Weld wheels are made to order. Weld stocks nothing.
I can say I got my wheels 4 weeks to the day and Hypermotive was cheaper than anyone else that I contacted.
phunk
United States
'15 GT-PP
Got any pics mounted on your car? 71LB7100A80A is a +61mm offset which is set pretty far in for a 10" wheel.
esacteksab
CO & KS
2015 Mustang GT
Not of the S71's. My first order didn't happen. 2nd order changed my mind and got S77b's.
Part numbers for S77b's
17x10 77LB7100A80A
17x5 77HB7050A22A
Part numbers for S71
17x10 71LB7100A80A
17x5 71MB7050A22A
Change the 77 for 71 and on the 17x5 Fronts, change the H to an M for the high pad instead of the medium pad on the S71's. On the S71 wheels, you can change the 'B' (black) for a 'P' (polished).
These are for NON-PP cars, PP cars would require an 18" wheel in the front (rears are the same on all GT's). Weld did tell me that an 1/8" spacer was necessary on the fronts for the S71 wheel, no spacer was necessary on the fronts for the S77b wheel. Though another member on the site did need a 3mm spacer on the rears for his S77b wheels.
Pics of the S77b wheels on my car http://mustang6g.com/forums/showthread.php?t=28251
phunk
United States
'15 GT-PP
17x10 77LB7100A80A
17x5 77HB7050A22A
17x10 71LB7100A80A
17x5 71MB7050A22A
These are for NON-PP cars, PP cars would require an 18" wheel in the front (rears are the same on all GT's). Weld did tell me that an 1/8" spacer was necessary on the fronts for the S71 wheel.
Any pics of the 77LB7100A80A on the rear?
I just want to see what a 17x10 +61 looks like. I would have figured you would want an offset more in the +45 range on a 10" wide wheel.
I have been looking at ordering some S71 in 17x11 for the rear and then getting the ET Street R in 305/45/17 whenever it becomes available
esacteksab
CO & KS
2015 Mustang GT
esacteksab
CO & KS
2015 Mustang GT
It looks great, thanks
It was a mess trying to order a set of wheels. I probably called Weld 3 or 4 times. Two vendors later and 4 months later, I had wheels. Once I ordered with Hypermotive though, as I said before 4 weeks to the day they were sitting on my porch.
jayman33
Fort Bragg, NC
Jason
15 PP
We have a decent system with weld, when you do a few sets a week with them you need to. I will say though that in the end the wait is well worth it.
