Gloucesternige
The bell should fit flush on the face of the hub Gibbo. If there's any interference with the od of the hub and id of the bell the kit is not fit for purpose and needs to be machined in the back face to give clearance.P.S. Is there anyway of measuring a disc run-out of a car? I ask because they are a very tight fit on the hub so maybe they are perfect but because the hub is marginally too large means even when torqued up the disc is not absolutely flat/perfect to the hub causing this run out as this run out is just as bad at hub so maybe the fitment is just too tight????
If I can get them measured off the car and if they are spot on I guess I could sand paper inside the bell and sand paper the hell out of the outside of the hub to create some more clearance so hopefully the fitment is not so tight, of course this is assuming this is the issue......
Best bet is first try to measure the run out of the car.
