The Menace
No it's not that Fast...
- Apr 24, 2015
- California
- Danny
- Mustang GT
YES! NEW PARTS
First big mobile upload from my phone. I hope this works...
So I made a little progress this weekend. I got a package and in this package was Steeda autosports Billet Aluminum Vertical Links , Adjustable Rear Toe Links , Hood Struts and Urethane Dif Bushing Insert System
So of course I got right down to business and tackled the hood struts first. Super easy probably all in about 40 minutes. Nothing crazy with the install the included instructions are easy as pie to follow and all you should need to get the job done. I will post more photos later for those.
Now for the fun one. The Vertical Links. I only had one day this weekend and Sunday it was. Started off only going to do a few preventative maintenance items when I decided What the heck its only 4 bolts and the car is already off the ground. So I started on the driver side on and off in 40 minutes.
Couple before shouts shame on ford these are so tiny......
Despite their size being like 5 times thicker they only weight about 2 pounds more. So if you trying to shave weight probably not what you want to add... Let's face it if your grabbing that ground first your 4lbs ain't gonna hurt you. Just lay off that big Mac and fries and your covered... Just sayin...
So the second one proved to be a pain in my a$$... After effing with this thing for way longer than I should have I walked away and came back later... After I remembered my A$$ was not a hat :headbonk:I pulled my head out of there and talked my way thru the problem. Attached a few pics down is a Pic with some comments. I hope they help.
A little after shot.
Little side by side.
Okay so the driver side I learned quickly to get the flathead in there and pry down while hitting with the rubber mallet and bam done. Lined right up and I was done.
Next came passenger side and for some reasons it got the better Of me. After coming back a little later had my sons friend give me a hand and as he was telling me what he saw the light bulb went off... Anyways hope this helps someone down the road.
Thanks for reading and go follow me on the gram @projectmenace
:cheers:
Danny
:cheers:
Danny
