RSKTAKR
- Apr 17, 2015
- kansas city missouri
- 2015 Mustang GT
ok update.. finished the install. I lossened up the rear sub frame bolts about 5 turns. got a little bit more room but still not enough. The easiest way for me to get these front bushings in was to put the bolt into the washer and bushing BUT the end (non head end) is FLUSH with the part of the bushing that is going INTO the stock bushing, you get the center of the steeda bushing past the lip of the stocker, then push the bolt in. This still doesn't give you the clearance you will need, you have push the steeda bushing UP with your hands or a hammer and screw driver. The head of the bolt will scratch up the plastic of the gas tank, but it will go in eventually.. the drivers side I just had to tap with a hammer and it went in lots easier. For those of you that also didn't get the grease I just loaded lots of Vaseline in there before I pushed all the steeda bushings in. I recommend a OPEN end 7/8" wrench because you cant get a closed end up there when you start tightening those front bushings. Hope this helps! End result is NO noise, NO knocking around or anything, and it hooks up GOOD!
