Steeda Tri Ax & Driveshaft Shop Install
Furious_S550
youtu.be
2016 Ford Mustang GT Premium PP
So yesterday I installed both short shifter and aluminum driveshaft on my 2016 Mustang GT. I followed the directions, videos and experience from installing short shift kits previously. But I'm still having a lot of undercarriage noise. Has anybody had the same issue. I thought it was the something might be loose but I triple checked everything. So now I'm thinking is just the sound coming from driveshaft.
Furious_S550
youtu.be
Klunk and metal on metal noise? I'm thinking it the shifter.
CommyO
Is it a v8?
Venus
15 EB Premium PP
It's normal. David has addressed that there will some NVH(noise) upon the installation of the tri-ax
BluByeU
M6G SoCal Cruisers
SoCal (Temecula)
Rob HT
2015 Premium GTPP Recaros & Shaker 401a
I can't comment on the possible noise coming from your DS but you will get a bit of noise coming from the Tri-Ax. Installed mine this past Friday, installed the dyna-mat but still can hear noise coming from the shifter area. Doesn't bother me at all, kinda goes along with the Muscle car feel IMO.
Furious_S550
youtu.be
Sorry, this is the noise I get when I engage the clutch. I'm hoping it's the steeda tri ax and not the driveshaft.
roadracergt
Detroit
2015 Mustang GT
Definitely the driveshaft. This is a characteristic of hollow aluminum driveshaft.
Just make sure the drive shaft bolts are tight, you should be just fine.
I kept my stock shaft in, for that same reason to much clanking.
Hope this helps.
tj@steeda
Timothy
Hope this helps.
To 2nd this ... I ran the video by our install dept. & engineering team - the sound that you provided does not appear to be a characteristic of the Steeda Tri-Ax.
Best Regards,
TJ
Furious_S550
youtu.be
Hope this helps.
Thanks for the info. I'll remove the driveshaft while I'm instilling my steeda springs this weekend. And all bolts were tightened to spec.
Furious_S550
youtu.be
Best Regards,
TJ
Thanks for looking into this.
Furious_S550
youtu.be
Removed the aftermarket driveshaft and the sound is almost completely gone. I'm going to wait until I change out the transmission fluid before I decided to take it to the dealer.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
While your under the car u could dynomat the tunnel, I'm sure that would quill most of the noises.
tj@steeda
Timothy
I appreciate the update ... keep the thread in the loop as you continue to move forward.
Best Regards,
TJ
