NatJoo
- Aug 20, 2018
- Edwardsburg, Mi
- Nathan
- 2016 Mustang Gt
Yes, we use our front coil over set up on our Silver Bullet which has remarkable short times for a N/A Street radial set up. pm your contact info and I will go over options that will address your objective.I really am interested in these but I am not sure how it will jive with what I am doing with my car. I am looking at 3/4" drop front and 1/2" rear. I have an Edelbrock SC that adds plenty of weight up front. Straight line traction is a necessity but I like a firm tight feeling car. My last car was a 15 PP that had steeda adj. set to 3/4 firm and BMR handling springs (firm as hell). The car felt great but it was a bit too low up front and the SC will make that worse. This seems like a good solution for getting the height I want but is it suited to straight line traction as well? Will it be as easy as popping the hood and softening up the front struts when I hit the strip or go to Mexico? Anyone car to give there experience on straight line traction?
Will these work on my 2021 pp1 car with ford performance track sway bars?Introduction price 1299.00 Regular price 1699.00
Ready to step up to an adjustable suspension setup on your S550 Mustang? Buy the one with the most research and engineering, and a National SCCA competition proven winner setup. Designed and engineered in the U.S.A! This kit will combine our Pro-Action Front Coilovers and our Adjustable Rear Ride Height Kit!
Steeda S550 Mustang includes custom designed Pro-Action adjustable front struts which feature rebound adjustment. Threaded collars and spring perches offer easy ride height adjustment from stock to 2" lowering.
The Steeda S550 Mustang Front Coilovers also includes our Steeda custom designed adjustable bumpstops! Allowing you to adjust your suspension travel for the ultimate in performance for any application.
The front coilover system also utilizes our Steeda S550 Mustang Camber Plates that provide - 3 degrees of camber adjustment.
Steeda's S550 Mustang Adjustable Rear Ride Height Kit will give you the ability to lower the rear of your S550 Mustang from 3/4" to 1-1/2", this kit allows you to dial in the ride height to your liking. The rear Ride Height Adjusters are made from billet 6061 aluminum in house and Hardcoat anodized for the ultimate in strength and protection. These simply install above the rear springs and come with an included wrench to allow you to adjust your height with ease. The Steeda kit is also designed with a locking set screw to hold your adjustment in place. Add in Steeda's Pro-Action Shocks for even more rear control and reduced wheel hop and body oscillation and you have a winning combination!
Product Benefits
- Designed, engineered, and tested on winning S550 Mustangs both on the drag strip and road course
- Ideal for any street or track Mustang
- Custom designed Pro-Action adjustable front struts with rebound adjustment
- Tig-welded and CNC machined pieces for exact tolerances
- Highest quality hardware
- Increased front grip, turn-in response, and cornering performance
- Specifically designed for the S550 chassis and front suspension system
- Ability to lower ride height 2" in front
- Ability to lower ride height from 3/4" to 1-1/2" in the rear
- Less damper friction, less side-loading on the shafts, lower internal pressures
- Bolt-In installation - No permanent modifications required
- National SCCA Majors competition proven winner setup
- Made in the USA
- Lifetime warranty
Yes, pm your contact info and I will go over the different spring options with you.Will these work on my 2021 pp1 car with ford performance track sway bars?
