Removing tape residue?
ShadesOfBloo
SE Virginia
Datsun wagon, '92 240SX, '08 Evo, '20 Mustang GT
I took my Mustang for inspection in December, and while it was parked overnight someone broke my rear quarter window.
I went around with plastic taped over my window for a while, and now I have residue from plain beige masking tape. It finally occured to me... I'm on a Mustang forum; Maybe I should ask them. šŸ˜…
How do I get rid of the residue without damaging my clearcoat?
The SafeLite technician suggested Goo Gone. Can you really use that on clearcoat?
WD Pro
United Kingdom
Lime GT
I would (without hesitation) use Goo Gone and even white spirit (mineral spirits over your side of the pond ?).
Start with a clean / freshly washed area, use sparingly, rub gently with a soft MF, rinse well, and then re protect :like:
WD :like:
gone_n_60
Indianapolis
Whit
2020 Mustang GT PP Convertible
You can try Griots Track Spray too. It's for removing rubber streaks from tracking, bugs dried on, etc. Goo Gone is a citrus product, most citrus based products loosen dried adhesive residues without damaging finishes, cars, cabinets, etc. But I've had good results with the Track Spray too.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Goo gone is great, let is sit for about 5 min should come right off. I have used it to remove double sided spoiler tape.
Believe it or not, WD40 will also remove tape/other sticky residue. Just spray it onto the residue, use a microfiber cloth to remove. Then just wash/polish after. The WD40 will NOT damage the clear coat, nor will it cause any issues using it in that manner..
GrabberBargeCaptain
CA
Could just use rubbing alcohol you have lying around. 70% should be more than enough
MAGS1
Somewhere in Middle America
Mark
2022 Mustang GT
Goo Gone or any adhesive remover that is safe for car paint will work. Just donā€™t let it dry on any of the painted surfaces (or rubber surfaces). I usually spray some on a microfiber, rub it into the glue areas and let it sit a few minutes. Then I get some clean, soapy water (warm water is extra helpful) and wipe all the remover off. Dawn dish soap will actually cut into it as well since itā€™s a degreaser. Just be careful if you have regular wax or a sealant on your paint, the Dawn will eat into it. If youā€™re ceramic coated you should be ok there.
MiamiGT350
S. Florida
Soak it in Goo Gone or an equivalent "citrus" remover.
They make an adhesive remover, which you might want to try.
Plastic scrapers should be paint-safe . As a fallback I usually use a microfiber towel to remove the adhesive.
There are also decal eraser wheels, but I've never been brave enough to use one.
MAGS1
Mark
2022 Mustang GT
I used an eraser wheel on my 2016 when I was removing old vinyl stripes. I didnā€™t like it and it was making me nervous that I was heating up the clear coat too much so I stopped. Plastic razor blades work pretty good, even those you have to be careful to not be at too sharp of an angle or they will scratch the clear coat (ask me how I know šŸ¤¦ā€ā™‚ļø)
MiamiGT350
S. Florida
Ahh good point!!!... I usually dull off the corner of the blade with a file. (Ask me how I know)
MAGS1
Mark
2022 Mustang GT
Yeah I didnā€™t do that and put a nice little scratch in my hood. Luckily it wasnā€™t deep and polished out just fine but was definitely an Oh Shit moment šŸ¤£. The new stripe ended up covering the spot as well but I didnā€™t want to leave a scratch for the next owner.
kilobravo
Corpus Christi, TX
kilobravo.com
KB
'16 CT6, '18 SD, '20 GT 500
I use them all the time, Mark, and find them very handy for all sorts of "scraping" jobs but, thanks to Miami's post, I know what to do in the future.
EXCELLENT tip and while I've never damaged paint with one, I will definitely round the corners next time, many thanks, Miami.
ShadesOfBloo
ShadesOfBloo
SE Virginia
I'm looking at the Home Depot web site and it turns out there are, like, 6 or 7 kinds of Goo Gone. šŸ˜…
I assume I don't want the graffiti remover or caulk remover.
I want the regular "goo and adhesive remover" right?
I don't need the "Pro-Power" stuff on my paint?
WD Pro
United Kingdom
Lime GT
ā€˜Goo & Adhesiveā€™ :like:
WD :like:
Hack
Minneapolis
Mustang, Camaro
Iso propyl alchohol is my choice for this type of issue. I've never had a problem using IPA for adhesive removal on paint or glass. I have used wax and grease remover in the past as well. Generic wax and grease remover is what painters use to clean and prep for painting. It's pretty similar to IPA in how it works.
