Woketman
Will the Aliexpress large size covers fit a 2020 GT front AND rear calipers? Or large for front, medium for rear? Or some other combo? Thanks folks....
I would %99 approve on fitment for fronts and back ! it's about the rims clearance .. check with the seller and flood him with questions and pictures before buying anything.Will the Aliexpress large size covers fit a 2020 GT front AND rear calipers? Or large for front, medium for rear? Or some other combo? Thanks folks....
Also prevent cooling of the caliper when needed. Which is really stupid.Second: More importantly, they help with keeping brake dust off the wheels, which is a big bonus.
What "stupid" exactly?Also prevent cooling of the caliper when needed. Which is really stupid.
How do you think a cover will keep break dust from getting on the wheel? I also cannot see any temp changes with those silly covers.MGP makes theirs out of aluminum and does custom color matching and lettering/logos. They are pricey but that would be the way I'd go if I did this.
Also want to add that covers serve two purposes, so they aren't just cosmetic.
First: they cover up the GOD awful looking stock calipers on the base cars. (sure you CAN paint them, but that's just putting lipstick on a pig. By painting them all you've done is drawn attention to the ugly stock calipers...FAIL)
I can go ridiculous, and say the alum cover would help reduce the heat. As they will act as a heat sink.It won't totally stop dust from getting to the wheel but any dust that gets on the back of it isn't getting on to the wheel and every bit helps.
And heat is an issue for sure if you are tracking the car and pushing it hard. But on the street, unless you ride the breaks like a grandma, it's not really an issue.
