R Hubs? R Spec suspension questions.
rushca01
FW, Indiana
GT350 Oxford White OTT
What advantage is there to going to front R rubs? Besides the longer studs?
I’m looking to use some of the r spec suspension parts (rear sway, springs) and go r spec on a set of forgeline GS1Rs.
Trying to piece the puzzle all together...lots of info out there but it’s hard to side through it.
Anybody have a comprehensive parts list?
FR3Z-5560-P & FR3Z-5560-T Left and Right Rear Springs
FR3Z-5310-M (x2) Front Springs
FR3Z-5A772-G rear sway bar
FR3Z-1109-A front hub
Norton961
Midwest
GT350
No advantage to the R hubs other than lug length which you don’t need with the Forgeline wheels.
If you want longer lug studs get ARP or MSI.
rushca01
FW, Indiana
Is there an aftermarket hub you run up front that allows you to run a square setup without spacers?
Norton961
Midwest
GT350
Nope.
I have 2 sets of Forgeline wheels.
I run 11x19 and a second set for track slicks on 11x18.
I don’t like using spacers myself.
raiderjatt02
Bay Area, CA
Jessie
2016 GT350 - Track Pack; 1995 GT - Saleen Clone
The only advantage of getting R hubs over getting longer studs is that you can keep your OEM hubs if you ever want to switch back. No need for a hydraulic press. I think the studs on the R hubs are longer than the ARP studs but I'm not sure.
Here's a picture of my Non-R hub next to the R hub that I swapped out.
firestarter2
NYC
RR G350 Track
they are longer
rushca01
FW, Indiana
From a conversation Paul A and I had at PK Auto
So a quick thing why is the R front hub different then the standard GT350. The 3" studs that come on the R are there because the Carbon wheels require the lug nut to sit on the face of the wheel not inside the hole. So to ensure that the lug nut sits on metal it sits a further 1" out hence the additional 1" longer stud.
Now the regular Gt350 does not need that so you are fine hence why we use closed ended lug nuts, while the GT350R uses open ended lug nuts front and back when they use any other wheel then the factor R wheels.
Paul A.
Zitrosounds
Madison, AL
Harold
Paul A.
The R uses the exact same lug nuts as a standard GT350 that are also shared on the Mustang GT
