2015 Mustang – EcoBoost 4 Cylinder Specifications
Dimensions
Compare (in inches): 2015 Mustang – wheelbase 107.1, length 188.3, width 75.4, height 54.4, front track 62.3, rear track 64.9
2014 Mustang – wheelbase 107.1, length 188.5, width 73.9, height 55.8, front track 62.3, rear track 62.9
Differences (2015 vs 2014 Mustang): (-.2) in overall length, (+1.5) in overall width, (-1.4) in overall height, (+2) in rear track
Engine
2.3 Liter Ecoboost I4 – 140 cubic inch/2,300 cc
- 305HP @ 5,500 rpm, 300 lb foot torque at 2,500-4,500 rpm
- 9.5:1 compression ratio
- aluminum block, aluminum cylinder head
- 3-port integrated into head exhaust manifold
- DOHC: 4 valves per cylinder w/ twin independent variable camshaft timing
- cast aluminum pistons
- forged steel connecting rods
- 87 octane fuel
- direct injection, 15.5 gallon fuel tank
- takes 6 quarts 5w-30
Drivetrain
-Standard 6 speed manual transmission (Hill Start Assist)
- Gear ratios: 1st: 4..236, 2nd: 2.538, 3rd: 1.665, 4th: 1.238, 5th: 1.00, 6th: 0.704
- Optional 6 speed automatic transmission (with paddle shifters)
- Gear Ratios: 1st: 4.17, 2nd: 2.34, 3rd: 1.52, 4th: 1.14, 5th: 0.87, 6th: 0.69
Suspension
- Front: double ball joint independent MacPherson strut & tubular sway bar
- Rear: integral-link independent rear suspension with coil springs, solid stabilizer bar & twin or mono tube dampers
Brakes
Front: 12.6inch x 33mm vented discs, twin-piston floating aluminum calipers
- Front: Optional Performance Package (standard on 2015 GT): 13.9inch x 12mm vented discs, four piston 46mm fixed aluminum calipers
- Rear: 12.6in x 12mm solid discs, single piston 45mm floating aluminum calipers, integral parking brake
- Rear: Optional Performance Package (standard on 2015 GT): 13inch x 25mm vented discs, single piston 45mm floating iron calipers; parking brake
Wheels + Tires
- Standard: 17 x 7.5 inch, 235/55R H A/S
Optional: 18×8 with 235/50R W A/S, 18×8.5 with 255/40R W A/S, 20×9 with 265/35R W, summer performance package: 19×9 with 255/40R Y
Dimensions
Engine
- 87 octane fuel
Drivetrain
Suspension
Brakes
Wheels + Tires
