Ninjavitis
I installed this system over the weekend and before start up I wanted to make sure I am not putting too much strain on the belt system. I needed to max out the OEM belt tension pulley to slide it over the pulley- when I let off the pressure on the belt tension pulley it did not really move at all and I am concerned the belt might be too tight. It is routed properly, I installed and reinstalled it twice. I used my hands to put the belt on, I did not use tools to force it so maybe it's just supposed to be this tight?
Belt: Vortech belt included with Paxton 2200SL kit - 103.31"
Using left to center pulley hole
Pulley: 3.8"
Will this belt stretch a slightly over time with some heat and tension? It is about 20 degrees here so I am not driving it currently and I am guessing the rubber will expand with some heat, but, I would like to know whether to swap to the middle hole to save excess wear on the belt system/crank before putting the upper IC pipes and everything.
Pulley: 3.8"
