Manders Mustang
The Boss
- Dec 3, 2015
- Birmingham - United Kingdom
- Steve
- 2016 Race Red Ecoboost
- Vehicle Showcase
- 1
Bolts are 7mm. ignore the ones around the fog lamp assembly (there's about 5 or 6) total bolts about 15. The two with washers connect to the actual bumper (the top and bottom side closest to the arch liner).My method:
- Jack
- Remove front wheel
- The 4 clips for arch liner, one on undertray, two at bottom, one higher up, this is it, no need to remove completely.
- Get your ratchet, can't remember the size now, undo the 7-9 bolts, again can't remember.
- Then unclip, helps by pushing from front.
- Remove enclosure, swap lights, refit.
No need for bumper removal, complete arch liner removal, the other option, ramp, remove undertray and fit that way. Bumper off should be your last method and is really un-necessary.
Clips on the most inside point can be a bit of a shit, but, if you remove all but those, you should be able to slide the indicator housing out as it's a separate unit.
I've done it once through the arch liner, and once with bumper off (Bumper was off because I was fitting grilles, and gloss fog lamps). Belly pan would also be a trick for it.
Kapt i used a flexi head screw driver with a 7mm attachment on it, that worked to get the more harder to reach bolts. (such as the two closest to the middle of the car, or the one hidden behind the fog (inside of car side). In retrospect bellypan off would have made those a walk in the park.
