Ohlins' Adjustable Coil-Over Kits Are In Stock At J&M / hotpart.com
Hotpart.com
Hotpart.com
San Luis Obispo, CA
2002, 2006, 2015 Mustangs
Everything sounds right, 514 lbs front, and 800 lbs rear, out of the box.
Do they have camber/caster adjustment or just fixed? Can we add aftermarket camber/caster plates?
The 25MM drop is only 1" I'm good with that.
Will you guys post the max spring rated you dyno to?
Thanks for getting it this far.
We will be offering them straight out of the box from Ohlins' along with different spring rates with the use of our patented camber/caster plates.
The springs in the photo are Vogtland but we will most likely be using Hyperco springs instead.
raidn
Utah
Ty
2016 GT Premium Perf Pack + 1968 302 Coupe
Yeah you're right, 25mm is a good drop. For some reason I was thinking that is more than an inch. I think that is about right.
SoCalTim
CA
Tim
Sold : 15 GT
Subscribed to see updates on this.
job
Roseville
74 Capri, 85 Audi, 2005 Dodge 2500,2017 GTPP
Has the dyno testing been completed?
job
Roseville
We haven't completed it yet. Fronts should be done shortly and hoping to have the rears done by the end of the week.
Are you talking Close of business today end of week, or some other time?
Real interested!
Hotpart.com
Hotpart.com
San Luis Obispo, CA
Here you go. We are waiting on the springs that Ohlins' wants us to run to try them out. Looks like these are setup to be a great street / autocross setup. If you want to road race with them we will need to re-valve the front rebound side.
Front
Rear
Hotpart.com
Hotpart.com
San Luis Obispo, CA
