OFFICIAL MAF flow rate lb/min flow rate thread!
Bluemustang
2015 Mustang Base GT
50.52 maf lb/min at 7800 rpm
Fuel trims 0%
30ish degrees outside
2018 ported intake
JLT
Gibson catback/X pipe
Chris Barnes
Arizona
2021 GT500
84.35 lb. min at 7640 RPM. 0 STFT. 8.1 lbs of boost. The cool weather here in Phoenix seems to finally be making a difference. Was only seeing 78 lb. min. in the middle of summer. Not sure if this is good or not, but the car feels strong.
Volstang
Knoxville, TN
Randy
2015 Mustang GT
Saw a best of 47.5 with 18 IM, 47lb, PMAS, Rob Shoemaker tune at 7200 RPM. Intake Manifold is out being ported and about to add LTs so we will see what that produces.
armykyle1 [HACKED ACCOUNT
Gulf Coast
2018 GTPP premium
So I didn't log LTFT, on my car.
But on my 93 tune with a pmas, I'm getting 51.5 to 51.8 with -3 to -4 STFT.
On the 100 octane tune, it was 53.5 to 53.9 and -5 to -6 STFT. 31.5° spark and -2 to -3 KNOCKR
I'll do a log with LTFT so the proper corrections can be made I guess
Red65
MS
Red 1965 Coupe, 2017 Premium MT GT
Has anyone done a direct comparison of dyne vs street MAF numbers using the stock airbox? Im curious about how well the ram air effect works.
whowasthat
ontario
2015 mustang GT
2015 GT Completely Stock:
LTFT 0.9375
STFT 1.03125
41.6436 @ 6633RPM
Taken on a summer Day
gimmie11s
SoCal
Murica!
Have you had it on the dyno? Curious how the lb/min rate compares to rwhp.
Volstang
Knoxville, TN
Randy
2015 Mustang GT
Update: After installing ported 18 IM jumped up to 48.41 with stock headers. Need to log again since I just installed LTs.
Chris Barnes
Arizona
2021 GT500
I have not had on the dyno. I've since added a methanol system and now I'm pegging the MAF at 86.6 above 7,300ish. Haven't touched the tune, but now no knock like before. I update if I ever get this thing on the dyno.
gimmie11s
SoCal
Murica!
Nice.
I’m pegging the MAF on 11 psi with twins.
I plan to have some dyno time in the next 2 weeks.
Andy13186
48.81 with just a k&n drop in filter pbd e85 tune in 80+ degree weather. Not sure what RPM it was at but my max RPM was 7573. Got the data via torque app in grams per second then converted to lbs per minute.
ManBearPig
Nashville
2016 GT
Reviving an old thread here
My last log showed a peak MAF flow of 47.3 lb/min (46.6 after applying fuel trim corrections).
2016 GT. TSP longtubes, JLT cold air, Lund 93 tune.
Bluemustang
At what RPM? You want to read where hp peaks. For you probably 6500-6800. Otherwise, MAF lb/min can keep going up but isn't helping you get more hp.
ManBearPig
Nashville
2016 GT
The peak 47.3 MAF value (uncorrected) in this log is at 6574 RPM. I would assume HP peaks around 6600? The MAF goes down to 46.9 at 7k RPM where I shifted.
