markmurfie
The injen does not have a removable insert. Its a stricly no tune needed intake.You've failed to answer the question regarding the insert and the no-tune version. Is it a no-tune with maf insert?
The Injen is a no tune intake. There is a part you can cut off which makes it necessary but mine is intact. The MAF is seated normally on the intake tubeYou've failed to answer the question regarding the insert and the no-tune version. Is it a no-tune with maf insert?
Did you ever go back to the factory box? And if so did it sole your problem? My car us doing the samethingThank you everyone for the help so far. I checked the MAF today and cleaned it, also checked again for leaks with a second set of eyes/ears. Revs seem a little better afterwards but still hangs up a bit. I'm probably going to drive it for a few more days and see if it shapes up. Otherwise I will probably go back to the stock box and see if there is any change. Pretty frustrating so far, hopefully it sorts itself out.
Hey! Sorry for the delay - I don’t have the mustang anymore unfortunately so I don’t monitor this forum much.Did you ever go back to the factory box? And if so did it sole your problem? My car us doing the samething
