VanFiveO
- Nov 2, 2022
- Vancouver, Canada
- Len
- 2021 Mustang GT PP1
Hey All,
Thought I would reach out to see if any of you know what might be wrong with my S550's shifter or tranny. Car is a 2021 GT PP1. I'll do my best to describe.
While still running the stock shifter the shifts felt sloppy, the shift lever would just fall into gears. The lack of resistance made it exceedingly difficult to find gears. Once in gear the car drove fine. Engagement of gears is totally okay. Fast forward to a month ago, I installed an MGW shifter (standard handle but x-spec), thinking it may just be the poorly built stock unit. The MGW unit is spectacular and at first seemed to resolve the issue. Very stiff but the loose feeling was gone.
Fast forward to now. As the shifter broke in, the loose feeling returned and as of today the leever just falls into gear. Not a good kind of falling into gear. Zero resistance. Gears still work fine and once in gear the car drives 100% okay. I can shift using a single finger until the gear is about to engage, at this point i get a slight bit of resistance. I've driven plenty of manual cars and never have I felt this before.
I'm going to double check all bolts on the MGW this weekend but don't believe this is the cause, as the problem existed with the stock unit.
Just thought I'd see if anyone may know where to start looking. Makes driving the car less of a joy.. now that the summer is here.
Thanks.
Thanks.
