Need more power to hit 11’s?
qtrmiler2
streator,il
greg
2018 mustang gt pp1
Bmr cradle lock outs.Been 1.88 on street tires and drag radials.Car is stock except for e85 tune.Ran 11.80s today.
cahouston
Houston
2019 Mustang GT A10 Premium
What did you have the rear air pressure at for the run?
How long of a burnout did you do?
cahouston
Houston
25 lbs about 7 to 10 seconds
I saw an article where the guy had best results on a well prepped track at around 20 psi. On a poorly prepped track, said 16 psi or less gave best result. I'm planning to get these when the rear MPS4S are done.
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
You need to be at 18-20psi cold, and no longer than 5-6 second burnout. You’ll drop to 1.66’s immediately and lower with practice.
qtrmiler2
streator,il
greg
2018 mustang gt pp1
I dont think so.The mustangs just dont have that low in grunt.I will need a full exhaust and a set of light wheels.Maybe a 1.7 60 then.
Glenn 70
Australia
Glenn
1970 mach 1 mustang
The car was consistent 12.2-12.3 today. I would like to break 12.0 in daily driver trim. I’m sure I could get another 10th or so as is, but not consistently run 11.8-11.9. I am thinking of going with the Ford performance power pack for my tune, but I am not sure if it’s enough power. I do have some e85 around, but I want to stay with 93. I would appreciate feedback from some 10R80 power pack owners on what kind of improvements in 1/4 mile they saw.
I know it’s not the same but here is my 16 auto with a tune ,axle back exhaust and M/T et streets .
Frosty_S550
SWVA
Nicole
19' Mustang gt
Car #625 this is my best 60 at Bristol on nitto 2s on 18 forgestar D5s 22 psi. Car only has x-pipe and Lund 93 tune. Fastest I’ve been so far hope this helps.
cahouston
Houston
With an estimated 2000ft DA for that track, day, and time, the MPH seems low. Did you let out or peddle due to lack of traction? What was your burnout and launch technique? Did you have advanced trac off?
Frosty_S550
SWVA
Nicole
19' Mustang gt
No I didn’t peddle or lose traction the prep wasn’t that good either. Left around 2500 rpm. Traction control was off she’s a base model so no advance trac. Did a burnout long enough to smoke a little then ran out till it bit in
