My Custom Audio Build - JL Audio/AudioControl
NotMarc
Earth
22 Mach 1
Okay did you completely cover the large hole in the door (where you can see the power window parts)?
I've got Noico CCF and KnuKonceptz CLD sheets.
Adams
Adams
Orlando
2017 GT PP
I didn’t cover it completely. I did add a little to the back of the interior plastic panel as well.
NotMarc
Earth
22 Mach 1
Okay I'll open it up and do that. I had that idea after the doors were back on
Thanks!
Doug
Georgia
2015 Ecoboost
Your system looks good! I'm in the process of adding the midbass to mine after having picked up the door panels. Did you buy the brackets or make spacers for the C7s? If you made them do you remember the thickness?
Adams
Adams
Orlando
2017 GT PP
Adams
Adams
Orlando
2017 GT PP
Reupholstering the rear seat delete with better material. I also reinforced the delete panels to make them more rigid.
OF5.0
Pittsburgh
Scott
2022 Shelby GT500 CFTP
How did you acoustically isolate the C7 mid from the woofer in the door?
Adams
Adams
Orlando
2017 GT PP
The door speakers have FastRings installed. There is also extensive sound deadening on the door panels.
OF5.0
Pittsburgh
Scott
Understood, but JL wants that mid to be in 0.4 L-sized enclosure to avoid interference from the back wave of the midbass driver.
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
I saw the same thing in their instructions. Both 3.5 mid and 6.5 bass drivers share the door cavity and back waves from the bass unit will create distortion in the midrange.
I plan on using these foam baffles behind the mids. It's not the ideal volume though. https://www.crutchfield.ca/p_237XT32/XTC-3-1-2-Speaker-Baffles-Slim-line-1-3-4-depth.html?tp=74192
OF5.0
Pittsburgh
Scott
An idea is the use of a resistive vent (aperiodic vents) in a modified small enclosure. Dynaudio used to sell Variovents. Scan Speak used to sell a version: https://www.madisoundspeakerstore.com/flares/ports/vents/scanspeak-290001-aperiodic-vent-ssv/
If the foam baffles don’t dissolve or melt when in contact with fiberglass resin, an aperiodic vent may be a great option.
I think that the linked vent is very oversized for your application, but they are simple to make.
Adams
Adams
Orlando
2017 GT PP
It is going to be difficult to get any level of a sealed enclosure on the door panel. I think my third phase of this install is going to be custom pillars with both mid and tweeter together.
OF5.0
Pittsburgh
Scott
The aperiodic enclosure has to be vey small, typically just enough to encapsulate the driver. A flush-mount tweeter cup could be used for the basis of the resistive vent.
chowman90
Canada
2015 Mustang GT
Did you have much issues using forscan to remove the eq / bass rolloff? Ive had no luck in finding that module to disable it
NotMarc
Earth
22 Mach 1
Are you in the correct mode? MS CAN vs HS CAN? only certain stuff is accessible in each one.
