Gibbo205
[MENTION=12964]Stark[/MENTION] The tyres are MPSS, thats why I am so surprised at the noise as when I put the MPSS tyres on the 19" wheels it was a massive improvement from PZeros. I have gone from 19" wheels with MPSS being fine to 20" tyres with MPSS being terrible.
And I really do mean terrible, I had to drive at 60 as 70 is just horrid.
Yes [MENTION=13889]djone101[/MENTION] I will get the balancing check and try again. It may wind its way up to you otherwise!!
What about alignment? Should I have had the 4 wheel alignment done having done away with spacers etc and if it is out, could it cause the noise to be worse.?
Wheels and spacers have no impact on alignment. So if it was already setup and as long as you have not bounced of any curbs or hit massive pot holes there should be no need for an alignment.
Your running a shorter tyre wall on these MPSS so the construction will be firmer which will transmit more noise though what your saying does sound shocking.
Vibration wise, remove wheels, clean both surfaces and then re-torque wheels in the correct way, nick them all up and then torque each bolt opposite to each other. Problem persist ask for wheels to be re-balanced.
Car should drive smooth, bigger wheels don't cause vibrations unless they are bent.
