Modifying As-Built Data Guide
ctandc72
VA
'19 GT 6 speed Base
Would this help with a Automatic model as well?
Not sure. But what I listed is what I changed and my drive modes now work. I'll to get a screen shot from FORSCAN with my settings this weekend.
Rash
Cary, NC
2018 Mustang GT Magnetic/Showstopper Red, 401A, Active Exhaust
Is there a way to remove sources from the available list? Is like to remove AM radio from even being an option.
drumstick
Oklahoma
2018 GT
Does anyone know if a way to pertinently turn off "tire pressure sensor fault" and the oil change light through the ForScan or is this even possible?
Long story short, I purchased a co-part 2018 GT that was wrecked and the buttons on the steering wheel do not work, the downshift paddle doesn't work and the turn signals. I've replaced the steering wheel, the buttons, the SCCM and the clock spring. I've checked the fuses in both inside and under the hood.
Also, is there a way to program the cluster to start up with a predetermined color selection and mode? Due to me not being able to press the buttons?
ktp1598
Mount Washington, Ky
Bobby
2019 Kona Blue California Special
Check to see if the BCM got any water on/in it.
drumstick
Oklahoma
2018 GT
Will do- if it got wet (in it/on it) would that explain some of the functions working? I would imagine none of them would be working.
-Does anyone know if a way to pertinently turn off "tire pressure sensor fault" and the oil change light through the ForScan or is this even possible?
-Also, is there a way to program the cluster to start up with a predetermined color selection and mode? Due to me not being able to press the buttons?
ktp1598
Bobby
It only affected my uncles left taillight not going off..ever. When I pulled the BCM the connectors were green and there was rain water under the carpet below the BCM. I scrubbed the connectors/plugs and even opened up the BCM and had to scrub the circuit board. 2005's were notorious for under the windshield water leaks so I sealed everything and the problem never came back.
briskspirit
Miami, FL
Igor
2019 Mustang GT Premium
BCM
726-46-02 xxxx xxx* xxxx Park Aid Feature Present Cfg: 0=not present, 1=present
APIM
7D0-04-02 xxx* xx Parking Assistance: 0=no PDC/PSM/SAPP, 1=rear PDC, 2=rear/front PDC, 3=rear/front PDC/SAPP (NA HMI), 4=rear/SAPP (EU HMI), 5=rear/front PDC/SAPP (EU HMI), 6=rear/SAPP (EU HMI), 7=rear/front PDC with APA, 8=APA Lite, 9=APA Lite Plus (SAPP/POA-10 channel)
--> 1 (not tested)
IPC
720-02-02 *xxx xxxx --> 5
PAM
736-01-01 4450 000B
736-02-01 0400 0400
736-03-01 0600 4200
736-04-01 0000 0000
736-05-01 0000 0000
I think this is all.
Regards
Falk
Is it possible to do on base model? Got rear bumper cover with sensors from premium model but can't find PAM module in ForScan and can't find address 7D0-04-02 in APIM...
Atticaz
Arizona
2017 Mustang V6
here are the byte values that AngelDeath has already discovered:
Police Dark Mode:
Code: 726-32-01: 0A01 0000 006B
Change to: 726-32-01: 0A01 0100 006C
Now your interior lights will not come on when you open your car door, or when you shut off the car! CONFIRMED!
I just tried this. Lights still came on. Also tried in my wife's 2018..... FORScan won't even link to her car. Says no ELM connection found.
Edit: I didnt change the B to a C and the end. Maybe That's why? I read in another post that it wasnt needed? can you confirm?
hlh1
Central VA
2019 GT PP1 A10
what is police dark mode?
Atticaz
Arizona
2017 Mustang V6
hlh1
Central VA
2019 GT PP1 A10
Supposed to make the interior lights stay off til you turn them on manually.
Interesting. Not sure I need this "feature".
Mustang_GT
Martha Lake
Kevin
2016 Mustang GT PP - Triple Black
It also makes the “Pony” mirror puddle lights inop when you open the doors. I put it back because I like the puddle lights.
hlh1
Central VA
2019 GT PP1 A10
I also like the puddle lights, and others like them also.
Since page 1 of this thread has not been updated in quite some time - can anyone post up the most current tool (hardware) used that works in conjunction with Forscan (software)?
Does it matter still if the tool is WiFi or Bluetooth - since again, Forscan has been updated multiple times since this thread started (as well as vehicle technology)?
AngelDeath
AngelDeath
CH, New Jersey
'20 Shelby GT500 Rapid Red / '01 Metallic Red C5 / '17 White Overland
Honestly Bluethooth, hardware wise nothing has really changed, unless if the newer model mustangs have had a change, at which point we would have to change to a different unit. So as of now the info is still accurate, if anything hardware has changed this please PM me and I will add the needed links.
