Modifying As-Built Data Guide
Threebanger
I am legend.
The Dirty South
Bray
2020 Twister Orange GT350
I now have navigation! Thanks to all who have contributed!
mustangmike86
fl
2016 mustang gt PP
Did you add navigation to a non nav unit with as built data, i have done this on a sync 2 unit with success and i have attempted this on sync 3 but could not complete it because i needed the navigation file. I would just like to know of anyone who has successfully done this to a sync 3
Threebanger
I am legend.
The Dirty South
Bray
Mine was sync 2.
Nuked
Morgantown, WV
2016 Triple Yellow GTPP w/Recaros
Pretty sure on Sync 3 the APIM is a physically different module for Nav/Non Nav/HD etc. Basically Ford wised up to the "mistake" they made on Sync 2 lol.
Nuked
Morgantown, WV
Anyone know if it is possible to enable the outside temp to display on the info screen in the gauge cluster? I know quite a few other Fords show it by the directional display, but I could not find a way to enable it via the normal settings anywhere.
My reasoning is with Carplay you lose that top strip on the 8" touchscreen that displayed the temperature.
TexasRebel
Gearshifter
between the mustard and the mayo
2016 YZ GTPP - PP2
I usually run CarPlay in the Ford screen for this reason... unless I'm navigating. CarPlay might not be able to pull data from the temp sensors, but it could sure use a weather app.
Nuked
Morgantown, WV
That's pretty much how I have been doing it.
I'll try and dig around this weekend and see if I can find anything that may work. I will be suprised if it is not in there somewhere. Nearly every other Ford I have driven gives the option to show temp in the gauge cluster.
Spart
Iowa
17 GT350
I don't know if this has been covered before, but this is Ford's method for encoding the VIN in the as-built.
30 = 0, 31 = 1, 32 = 2 [.. etc ..] 39 = 9, 41 = A, 42 = B, 43 = C [...etc..] 49 = I, 4A = J, 4B = K [..etc..] 4F = O, 50 = P, 51 = Q [... etc ..] 59 = Y, 5A = Z
Seems to show up in
760-01-01 through 760-01-04 (ABS)
7A7-02-01 through 7A7-01-04 (FCIM)
726-09-01 through 726-11-01 (BCM)
737-01-01 through 737-01-04 (RCM)
zackmd1
Zack
From what I have heard, non nav sync 3 units have less internal storage then nav units. So the hardware is different and likely will never be able to activate nav on a non nav APIM.
zackmd1
Zack
I wonder if you changed the as built data and then used the navigation sync 2.2 update if it would work and give you the nav files.
As I just said though, the non nav APIM has less internal memory then the navigation APIM so it likely would not work.
mustangmike86
fl
2016 mustang gt PP
I heard the same thing but i do not believe this because if you look at the sync 3 version 2.2 updates the non nav is actually a larger file then the nav file. I have also turned the nav icon on with the as built data already,
Built4Speed
2016 GT Premium White
I can't get this to work. I have the Bluetooth OBDLink MX adapter. My PC is connected to it. But I am getting an error.
StangATX
Project Corrupted Cyclone
Austin, TX
2016 S550 White Corrupted Cyclone
Keep trying to connect with ForScan it happened to me. I had to give it a shot a couple of time.
[email protected]
florida
Nick D
red gt auto
Or contact the developers. They are pretty responsive. When i added PP2 to my '16 ForSCAN wouldn't connect anymore. They pushed me a beta that included connecting to PP2 cars.
Did you lose whatever changes you had already made when the tune was installed?
