detailz03
- Dec 8, 2014
- Antelope Valley
- Michael
- 77 Corvette Black W/Flames
Please post all known issues with the mustang here so when people get their cars, they can check to see what to look for.
Please post the issue and how you found it. I'll edit my post to make one LARGE master list. Credit will go to the posters.
Thanks!
User Submissions
(AngryBeavers) Buzzing from the left side of the dash where the headlight knob is. Most noticeable after hitting a bump in the road.
(IcanCRF) *Panel alignment. I found my hood alignment to be off and closer to one side of the fenders.
*Muffler tip alignment, A muffler shop used a tape measure and pointed out my stock exhaust tips were not symmetrical from the factory as one was drooping noticeably more than the other. They then adjusted the tips accordingly when they deleted my resonator and welded my H-pipe in.
*Muffler rattling noise. Upon cold start ups, my muffler will rattle and the rattling sound abruptly stops. I have yet to discover the source of the rattle.
*Brake squeal. Intermittent brake squeal at slow speeds and when the car is cold.
*Paint run. A small clear-coat run was discovered behind my rear paper plate. As it is covered by the license plate, I will leave it alone due to the risk of further damage.
(icarumba) It would also be helpful to identify what type of car you have. Here's mine:
V6/AT/Convertible
*Crack in dash panel - passenger side. How the hell this wasn't caught at the factory OR during PDI is beyond me:
*Vibration between 50 & 70 mph (drive shaft replaced):
*Dimple in black trunk panel (It's not a dent - I think it is a poorly designed mold. The replacement panel has the same defect):
*Ripples in convertible top at both rear corners (not the normal wrinkles).
*Seatback release (on back of seat) hard to operate - passenger side.
*Steering wheel makes a "wheezing" sound when turning (no, it's wasn't me wheezing...I checked ).
*A/C takes 6 minutes to blow cold, then goes back to ambient temp after 3 minutes.
(Guio) Mine's an "early" build (Oct 14'). Here's my gallery http://imgur.com/a/cUQaC , and summary of all of my Ecoboost's issues:
1) Engine: The car vibrates most of the time, and it's most noticeable whenever I go over 50MPH (since Dec 2014).
2) Automatic Transmission: It kicks/jolts from 2nd to 1st (vice-versa) quite often (since Nov 2014).
3) Turbo: High pitch noise whenever it's boosting (since November 2014). Youtube video: https://www.youtube.com/watch?v=WAKssW0L1VI
4) Noise right after I shut my car off (since Jan 2015). Youtube video: https://www.youtube.com/watch?v=MU9gl6b-jdM
5) Body Misalignments: Front and back bumper (driver side), Back Glass (one side is lower than the other). Driver side door or trunk aren't perfectly aligned, but I don't mind since it's hardly noticeable.
6) Leather Stitching: The back seat wasn't stitched correctly.
7) Aluminum Dash board: It's not perfectly placed on the passenger side. It sticks out a bit, and rattles from time to time.
8) Interior rattling: Aluminum piece (dashboard), and in the back (passenger side). Youtube video: h/ttps://www.youtube.com/watch?v=E-eJSjNRM3c
9) Trunk's Weatherstrip: It's coming off.
10) Door's Rubber Seal: Deformed, or not installed correctly.
11) A/C's Physical Controls: They randomly (but rarely) stop working. Youtube Video: h/ttps://www.youtube.com/watch?v=VYtGMTbk9d8
(Bay1Stang) My V6/AT/Coupe issues:
-Check engine light on at 50 miles - catalytic converter replaced.
-Minor hood misalignment. The driver side is slightly higher.
-Rear glass misaligned.
-Trunk lid misaligned.
-Rattle in the glove box area.
Thanks!
User Submissions
V6/AT/Convertible
