Furiousone
- Mar 2, 2018
- Central IL
- 2018 Ford Shelby GT350
Thanks guys- I'm sure as I proceed I'll ask more questions as needed.
Correct. I have it set to the 6 screen, I have RPM, (shift lights come on) ACl % ACL learn, IA Temp, Knock, AFR, and I forget the last one.ALC % is one of the gauges you can have displayed
But there is no ethanol sensor in the system so how is it measuring alcohol content? I set mine up and it’s reading 91. Measured fuel with test tube setup shows about 77 right now as we still have winter fuel. For a true reading you need to set up a Ethnanol sensor inline with a controller and send it’s analog signal to the ngauge to displayALC % is one of the gauges you can have displayed
that is exactly what mine did. it is not very accurate, but it can distinguish between 93/e85 and a myriad of mixes in betweenBut there is no ethanol sensor in the system so how is it measuring alcohol content? I set mine up and it’s reading 91. Measured fuel with test tube setup shows about 77 right now as we still have winter fuel. For a true reading you need to set up a Ethnanol sensor inline with a controller and send it’s analog signal to the ngauge to display
Most likely it is doing it based on fuel trims. So say the car wants X amount of fuel at a given RPM/load on 93 octane. If the car now is learning an extra 15% fuel addition in that area, you can roughly math out the ethanol content.But there is no ethanol sensor in the system so how is it measuring alcohol content? I set mine up and it’s reading 91. Measured fuel with test tube setup shows about 77 right now as we still have winter fuel. For a true reading you need to set up a Ethnanol sensor inline with a controller and send it’s analog signal to the ngauge to display
Understood. Just trying to get the value reported and it’s accuracy. I have the flex tune running and a E85R tune which is more aggressive that is written for 85 percent in the tank. I need to be up to at least 83The ecu learns the ethanol content in exactly the same way all Ford flex fuel vehicles do. Ford engineers abandoned standalone fuel sensors years ago in favor of the current system and apparently are satisfied with the results.
So I assume you installed the tune, ran the 93 out then put in the E85. Then drive the car gently until the fuel trims update, then beast mode? Who did you order through? So close on pulling the trigger on this....I recently had my car tuned via Lund. I'm loving the flex fuel tune, the car really comes alive with e85 in the tank. I was skeptical about how much of a difference fuel could actually make, but I was wrong. The car was amazing on 93, but just goes into Beast-Mode on e85.
Whoever mentioned it earlier, they are correct, gas mileage on e85 is absolute crap. Ethanol has about 30ish % less energy than pump gas, so you'll burn through gas that much faster. I can easily burn through a half tank going on a few hours drive with the boys.
I ordered the tune and nguage directly from Lund, but Beefcake and others can provide the same services as well.So I assume you installed the tune, ran the 93 out then put in the E85. Then drive the car gently until the fuel trims update, then beast mode? Who did you order through? So close on pulling the trigger on this....
