PRG3k
Thanks for the reply. I do not feel my car is special in any way and don't think my experience should be weird or atypical to any other cars running an upgraded intercooler. Maybe the fact that I have really beat on that smaller MAP unit for a while in serious Florida heat gives me a different perspective than others that went straight to a large core from the stock intercooler. I glance and take in the charge air temp stat on the Accessport every 5 minutes while in the car and have for about a year now.All concerns I had about upgrading. I'll be testing the MAP race as soon as I get it which is similar to the Levels unit with half of it sitting behind the crash bar. My theory about why it heats up faster than a stock location are
1) more surface area, which is a benefit for dissipating heat but also allows more heat to be absorbed faster.
2) Heat rises. A stock mount intercooler is 100% under the radiator, heat can and does radiate in all directions but when it hits air, the air becomes less dense and rises. If you ever had one of those small BBQ grills you can put the cover on it and in a few minutes feel the heat rising off of it to where you can hardly get close, Move your hand to the bottom and you almost have to be touching it to feel the heat.
The levels (and the MAP Race etc.) all cover part of the radiator, heat has a much easier time reaching adjacent rather than lower areas and the top half of the IC is higher than the bottom half of the RAD.
When you are moving all these problems go away, but they are liabilities in traffic.
I'm also concerned that half the core is blocked, Id rather have 50% of the core doing 20% than 40% of the core doing 10% or less.
My torture testing will tell all and I am prepared to hand the win to the street core if the Data leads me there.
The characteristics of the two intercoolers are very night and day. I ran around town on the MAP unit all day long in mid 90's heat. Spent the afternoon swapping the Levels out and changing the oil to where I finished at around midnight when temps were 15 degrees cooler. And right out of the garage after a couple very spaced out stoplights, charge temps were already bouncing between 110 and 120. It surprised me on that test drive and went back into the garage kind of scratching my head.
On the flip side, I also noticed that it recovered a lot faster than the MAP unit. 5 or 6 degrees would fall out of it just from a lazy run through 1st gear. And giving it 50% throttle through a taller gear would dissipate close to another 10 degrees. The MAP unit would react with about half that temperature drop under the same circumstances.
Now remember I have not done any WOT logs on E30 yet with the Levels to see if the playing field levels out (pun) under full throttle. My suspicion is that it would.
In my honest opinion I think its close to a wash. The MAP unit seems slow to rise, slow to fall. And the Levels with more heat soak but a more effective reacting core. Depends on the driving style you want and power you are pushing.
I also want to look into utilizing channeling for the lower bumper. Ford really seems like they were locked in a room for months on end thinking out the front airflow for this car; Whether it be the stock airbox that works so well, to the active grille shutters that there's been enough debate on.
One thing about the shutters, someone mentioned this a while ago, was that if you could keep the housing but remove the active fins that moved up and down, there seemed to be a 'channel' or guide for the air into the stock intercooler location. The shutters are gone and now, since I installed the Levels, also gone are that mess of black plastic fins and flaps (that guide air to the stock airbox and cover the stock IC endtanks) which hook onto the AC condenser. There is a lot of empty space around the intercooler now but is it helping, I'm not sure.
