firestarter2
If you have fords factory map you dont need to do all that work all the tables are populated already for you. Its really how far you want to go.
A small change in a/f and timing can be done fairly easily and gain power. If you want to control the variable cam timing etc that a much bigger bear but I dont know if they do that.
You are making it overly complex.
I'm not.
First of all, I dont know what kind of software Ford uses and how their stock tune is. My experience is limited to my M5 which uses dual Bosch DMEs, it's pretty high end stuff. But I'm guessing GT350 is no slouch and it must be similarly equipped/coded.
M5 has various tables, tables are like 2D matrixes that allow the computer to lookup values given X/Y axis values, such as atmospheric pressure vs temperature MAF lookup or humidity etc. My car has pretty advanced lookup tables that define injector pulses for a given MAF and MAP reading (I'm guessing mustang must have a MAP sensor as well) and same goes for Lambda sensors (there are four oxygen sensors). Think of the DME as a giant table lookup software that constantly does nested lookups (one lookup leading to the next, so on).
Now the problem isn't the ability to modify those tables, that anyone can do. The problem is coming up with the values that goes in those tables. Some of these tables require wind tunnels as well as the car having to be tested at different parts of the world. BMW always tests their car in places like Arizona, las vegas, sweeden, finland, africa, etc.
A tuner will never be able to match a factory engineer's ability to fine tune this software. They will maybe get 60% close which will make 90% of the population happy because very little people know this stuff as much as I do. But still, it doesnt mean what they are doing is right or reliable. No one knows the long term impacts of such modifications (i.e. 50-60k miles).
