It's HERE! 🎉 Elite Series Sequential Foglight for 2018+ Ford Mustang | Diode Dynamics
Diode Dynamics
St. Louis, MO
www.diodedynamics.com
2015 Mustang EcoBoost
Diode Dynamics is excited to introduce the Elite Series Combination Lamps for the 2018+ Mustang!
These lamps are a direct replacement for the 2018-2021 Ford Mustang's factory combination fog lamp housings, but provide greater functionality, maximum output, and a unique appearance. Designed for perfect fitment, these combination fog lamps illuminate in a cool white for your parking lights and DRL, and add a sequential turn signal as well as a modern startup sequence. They feature a gloss black bezel finish that matches the OEM headlights and are one of the best ways to easily add styling to your Mustang!
Aggressive appearance. The OEM combination lamps have a chrome appearance that sticks out from the blacked-out headlights. The Elite Series Combination Lamps have a gloss black bezel finish that matches the headlights for a more aggressive appearance on the road.
Unique startup. Not only do these lamps provide an increase in performance, they also feature a unique startup sequence. Anytime you unlock or lock your Mustang, or open the doors, they will turn on in a startup animation. The lamps sweep on before sequencing off, and then gradually ramp-up to full brightness.
Fog upgrade. The fog light optic has been completely redesigned to be larger with a sharper cutoff, wider beam pattern, and 30% more light output than the stock fog.
The fog light is available in a cool white or selective yellow color. The white is a 6000K color temperature, which is a true cool white output, and matches the factory headlights. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a distinctive look on the road.
Sequencing turn signal. Anytime you hit your turn signal, they light up in a programmable sequential amber pattern, just like the factory tail lights, to indicate signaling. Use the integrated switch to choose between U.S., E.U., and static blink rates to achieve your own custom look!
  • US: Sequential turn signal rate that matches the USDM tail lights​
  • EU: Faster sequential turn signal rate​
  • Off: Static, non-sequential turn signal​
High-power DRL. These combination fog lamps operate as an extra, high-power daytime running light, so you can show them off day or night. The included harness connects to your headlights and enables them to light up with high intensity for visibility even in direct sunlight.
OEM-fitment. At Diode Dynamics, we use a 3D scanner to develop plug-and-play replacement housings that will be a perfect fit. Simply remove the original housings, and ours will fit directly in its place. They also use OEM connectors that plug right into the factory socket.
In the Box:
NOTE: These lamps are not compatible with the Shelby GT350, GT350R, and GT500 models.
See how to install our Elite Series Combination Fog Lamp for 2018-2021 Ford Mustang!
Reliable operation. Like most Diode Dynamics products, these Mustang combination fog lamps are designed with newer constant-current circuitry and transient voltage protection. These features, found in factory-installed lighting components, protect the circuit over time, ensuring years of flicker-free performance.
These lamps were designed to last the life of your vehicle, and have been subjected to advanced transient voltage testing. These tests replicate the electrical wear and tear experienced in automotive environments every time your alternator starts and stops, which is what kills less robust electronics over time. They are also tested for long-term operation from -40 to 185 degrees F, vibration, and corrosion. All of these tests are completed to SAE/DOT standards, just like the factory components.
Diode Dynamics Elite Series Combination Fog Lamp for 2018-2021 Ford Mustang are proudly assembled in the U.S.A, and are backed by a 3-year warranty.
If you have any questions, please don't hesitate to post, PM, or email [email protected].
PM us for the free-shipping code (U.S. forum members only)
Thanks for looking,
John C.
Diode Dynamics
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
These look awesome!
Diode Dynamics
Diode Dynamics
St. Louis, MO
I like them just not the price.
Hey there!
It's important to compare the factory fog lamp assembly retails for $1000 brand new compared to our Elite Series Combination Fog Lamp for 2018-2021 Ford Mustang that is proudly built right here in the US at our facility in St.Louis, Missouri.
They're also engineered and designed here for a focus on maximal performance and the highest standards of quality on the market. Our engineers have designed our combination lamp to be the best possible product offer for Ford Mustang owners and are backed by an 8-year warranty.
Our fog lamps have been completely redesigned with a bigger optic to provide far more intense output, sharper cut-off, and a wider beam pattern compared to the factory fog lamp projector.
Plus, we've designed these with an added sequential LED turn signal, programmable speed, unique startup sequence, and a smoked bezel for a more aggressive appearance that pairs great with the factory headlights!
John C.
Diode Dynamics
Smunczen
Atl
Scott
2020 mustang gt pp2
If I needed to replace the factory stuff I’d look at them. As of now cannot justify the cost vs the return. That’s just me.
Louk
America
Lou
F90 M5, 2022 TRX
Finally! I have been waiting on something similar to the switchbacks I had in my 16!
this is my next purchase for sure, thanks for finally getting this out!
JohnnyGT
NoVA
'20 Mustang GT, '17 Expedition, '04 LS430
Them yellow fogs...I want. 🤤
Diode Dynamics
Diode Dynamics
St. Louis, MO
Thanks for the positive feedback everyone!
We're proud to offer this product to the Mustang community.
Please, feel free to PM us for a free US shipping code anytime!
John C.
Diode Dynamics
DougS550
Indiana
Doug
I already ordered a pair with Yellow Fog Lights. BUT: They don't come in untill October, 😈
Diode Dynamics
Diode Dynamics
St. Louis, MO
Trust us! They are worth the wait 😎
John C.
Diode Dynamics
DougS550
Indiana
Doug
For the quality of US made parts a huge plus for me. Higher lumen Yellow Fog lamp a huge plus. $400 for a set, absolutely worth it compared to OEM, sequencer turn lights Great. I hope when I get them they are as advertised. Can't wait.
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Please post a write up on the forum when you get them.
