OrangeCRSH
Asked my local dealership today about getting the wiring. I swear they know nothing there lol. Parts guy says I’d have to buy a $400 entirely new wiring harness if I wanted the guages!
Facing the exact same issue! Have you get around it and make it works all the time?at this point I really dont know what to do... my car its a late 2015 (Premium GT) when I removed the radio the harness was literally hanging there so never had tu cut any wires... with HP tuner I changed the Oil Pressure from Switch to transducer then using Forscan I changed the IPC As-built programming 720-02-01: XXXX XXXX X7XX (I had XAXX)
the gauge works randomly and when it works it shows the low preassure Oil...
yep,I used vcm editor change the oil pressure switch to transfer already and I changed the oil pressure sensor.one wire sensor change to 3 wire sensor.I have confirmed that the wire is correct.The sensor 1 pin to PCM 21 pin, sensor 2 pin to PCM 41 pin, sensor 3 pin to PCM 25 pin.The very strange thing is that the instrument panel can now display,but when I riseup RPM, the instrument will not jump towards the correct value and will always display around 50PSI.Using the HP VCM editor have you gone to the oil pressure switch/sensor function screen and toggled the command from looking for a pressure switch signal to sensor signal. If not the PCM may be just seeing the open/closed switch signal and not a variable sensor signal. You also must change the pressure switch to the sensor and wire in the 3 wire sensor pigtail to engine harness wiring. It's all outlined in this thread.
BD
Those should be the correct PCM pin numbers your using, I assume you are using the correct sender part number as well. Dies the oil pressure drop some as the engine warms up or does it read 50 psi regardless of temp or rpms.yep,I used vcm editor change the oil pressure switch to transfer already and I changed the oil pressure sensor.one wire sensor change to 3 wire sensor.I have confirmed that the wire is correct.The sensor 1 pin to PCM 21 pin, sensor 2 pin to PCM 41 pin, sensor 3 pin to PCM 25 pin.The very strange thing is that the instrument panel can now display,but when I riseup RPM, the instrument will not jump towards the correct value and will always display around 50PSI.
yep,the part number is CM5Z-9D290-B,I know the oil pressure will decrease when the engine speed drops,The problem now is that the oil pressure won't rise when you press the accelerator,I have watched many videos, and when their speed increases, the oil pressure gauge will rise from 50PSI to 80PSI and then decrease again,But mine has always been around 50 and won't rise,Very strange.Those should be the correct PCM pin numbers your using, I assume you are using the correct sender part number as well. Dies the oil pressure drop some as the engine warms up or does it read 50 psi regardless of temp or rpms.
BD
That is strange and could be a faulty dash gauge that will not go above 50 psi.yep,the part number is CM5Z-9D290-B,I know the oil pressure will decrease when the engine speed drops,The problem now is that the oil pressure won't rise when you press the accelerator,I have watched many videos, and when their speed increases, the oil pressure gauge will rise from 50PSI to 80PSI and then decrease again,But mine has always been around 50 and won't rise,Very strange.
I have replaced two instrument panels and both have the same fault, so I am wondering if the EB of 15-17 is different from the EB of 18-22That is strange and could be a faulty dash gauge that will not go above 50 psi.
BD
I'll shoot a video and you'll knowThat is strange and could be a faulty dash gauge that will not go above 50 psi.
BD
That is odd for sure. The only other thing I can think of and it's a long shot is your PP gauge cluster is for a NA GT not an ecoboost so possibly there is some difference in the circuit board of the GT gauge causing the issue since your vac gauge should read from -25 to +30 IN/HG versus just -25 to 0 vacuum. There are different gauge packs for a GT and ecoboost as well as S/C cars like the GT500.I have replaced two instrument panels and both have the same fault, so I am wondering if the EB of 15-17 is different from the EB of 18-22
I don't think so, because I have two gauges and the other one is from ECOBOOST, which is the same problem,so this makes me very confusedThat is odd for sure. The only other thing I can think of and it's a long shot is your PP gauge cluster is for a NA GT not an ecoboost so possibly there is some difference in the circuit board of the GT gauge causing the issue since your vac gauge should read from -25 to +30 IN/HG versus just -25 to 0 vacuum. There are different gauge packs for a GT and ecoboost as well as S/C cars like the GT500.
BD
There is also a very strange thing, I don't know if you have noticed that if the PP instrument is not correct, the display on the LCD should be correct, but the LCD display is also not movingThat is odd for sure. The only other thing I can think of and it's a long shot is your PP gauge cluster is for a NA GT not an ecoboost so possibly there is some difference in the circuit board of the GT gauge causing the issue since your vac gauge should read from -25 to +30 IN/HG versus just -25 to 0 vacuum. There are different gauge packs for a GT and ecoboost as well as S/C cars like the GT500.
BD
