Yea the video is old lol but looks like it still applies. The reservoir in the vid also only has two top ports
ROFL
Ouch. Hope the heli-coil works.Got new hardened (non-Chinese junk) hardware for the 4 corners. Studs in the right length weren't available. Cleaned all 4 corners, chased the threads with a tap on all 4 corners. Cleaned up the wonky hole before and after chasing it with a round brass brush for cleaning guns. Reinstalled the head unit. We put the bolts in, and started the torque sequence and pulled the threads on that hole right out before hitting the first number.
Heli-coil time...
You may want to try and use a different torque wrench, maybe the one you are using is not accurate? You're using inch lbs, not ft lbs, correct? I've seen people snap intake manifold bolts before thinking the instructions are referring to ft lbs, but they actually refer to inch lbs.Got new hardened (non-Chinese junk) hardware for the 4 corners. Studs in the right length weren't available. Cleaned all 4 corners, chased the threads with a tap on all 4 corners. Cleaned up the wonky hole before and after chasing it with a round brass brush for cleaning guns. Reinstalled the head unit. We put the bolts in, and started the torque sequence and pulled the threads on that hole right out before hitting the first number.
Heli-coil time...
I'm aware. It wasn't a torque issue last night, it was a lack of good threads. I appreciate the thought, though.You may want to try and use a different torque wrench, maybe the one you are using is not accurate? You're using inch lbs, not ft lbs, correct? I've seen people snap intake manifold bolts before thinking the instructions are referring to ft lbs, but they actually refer to inch lbs.
88 in lbs first pass, 106 in lbs second pass. That's only like 7-8 ft lbs of torque.
