Cobra99
I don't want to get in a debate on which oil to use but I run 5w50 Sig Amsoil in my two GT500. Also my Son's built Focus.So your true syn oil is 100% Group IV PAO ? No other groups mixed into the oil blend ?
I recall seeing a product test review comparing a number of different brands of full synthetic motor oils and compared to conventional or blends, most of the full synthetics were fairly comparable. Yes, there were slight variations but they were all generally in the same ballpark. I think they're all pretty much OK; I use Napa brand full synthetic for my other cars but use either Mobil 1 or Castrol synthetic for my GT (just a "mental" thing as I'm sure the Napa would be fine in the GT as it's manufactured by Ashland Oil, the ones who make Valvoline). Pretty sure the Walmart stuff is comparable as well though it wasn't in the test article I read back then.For a full synthetic, what do you recommend?
Yea, just keep in mind that Walmart is not a producer, so they buy from someone who might be the lowest bidder. Does not mean that it is not a good product. Just make sure that it has the specification approval emblems (starburst and such). None of the majors spend the millions that it requires to formulate a really high-performance oil in a specification. Nowadays they formulate to the spec and they are good to go. They leave the tiny part of the market that wants Super Performance Racing Space Shuttle Approved oils to the boutique blenders, who do a very good job a it in most cases. For companies like Exxon Mobil, Chevron, Conoco Phillips, et al. it is simply not worth what it cost to produce these products, market them, and for the Marketers to have to stock small volumes of them in their warehouses. So, they leave it to Redline (actually owned by Conoco Phillips), Amsoil, Driven, to service that market and take the comparatively small market share. It is all decided by the Benjamins. And in this case the bean counters win at each of he big producers. It is just not worth their time. Something about the the juice and the squeeze.I recall seeing a product test review comparing a number of different brands of full synthetic motor oils and compared to conventional or blends, most of the full synthetics were fairly comparable. Yes, there were slight variations but they were all generally in the same ballpark. I think they're all pretty much OK; I use Napa brand full synthetic for my other cars but use either Mobil 1 or Castrol synthetic for my GT (just a "mental" thing as I'm sure the Napa would be fine in the GT as it's manufactured by Ashland Oil, the ones who make Valvoline). Pretty sure the Walmart stuff is comparable as well though it wasn't in the test article I read back then.
I perform contract work for an OEM of high speed rotary filler machines. Most automotive and powersports enthusiast would tip over if they seen all the different manufacturers oil bottles shipped in for factory acceptance testing and loaded onto the same filler feeder conveyor.Yea, just keep in mind that Walmart is not a producer, so they buy from someone who might be the lowest bidder. Does not mean that it is not a good product. Just make sure that it has the specification approval emblems (starburst and such). None of the majors spend the millions that it requires to formulate a really high-performance oil in a specification. Nowadays they formulate to the spec and they are good to go. They leave the tiny part of the market that wants Super Performance Racing Space Shuttle Approved oils to the boutique blenders, who do a very good job a it in most cases. For companies like Exxon Mobil, Chevron, Conoco Phillips, et al. it is simply not worth what it cost to produce these products, market them, and for the Marketers to have to stock small volumes of them in their warehouses. So, they leave it to Redline (actually owned by Conoco Phillips), Amsoil, Driven, to service that market and take the comparatively small market share. It is all decided by the Benjamins. And in this case the bean counters win at each of he big producers. It is just not worth their time. Something about the the juice and the squeeze.
Yes, I figure that if the API specs on the oil meets or exceeds what Ford requires, we're good to go for normal everyday use. I don't track the car so most of what's on the market works fine. I'm not sure if the Mobil 1 and Castrol are much better than the Napa branded stuff, but it just makes me feel better to feed my good car with those.Yea, just keep in mind that Walmart is not a producer, so they buy from someone who might be the lowest bidder. Does not mean that it is not a good product. Just make sure that it has the specification approval emblems (starburst and such). None of the majors spend the millions that it requires to formulate a really high-performance oil in a specification. Nowadays they formulate to the spec and they are good to go. They leave the tiny part of the market that wants Super Performance Racing Space Shuttle Approved oils to the boutique blenders, who do a very good job a it in most cases. For companies like Exxon Mobil, Chevron, Conoco Phillips, et al. it is simply not worth what it cost to produce these products, market them, and for the Marketers to have to stock small volumes of them in their warehouses. So, they leave it to Redline (actually owned by Conoco Phillips), Amsoil, Driven, to service that market and take the comparatively small market share. It is all decided by the Benjamins. And in this case the bean counters win at each of he big producers. It is just not worth their time. Something about the the juice and the squeeze.
The European testing and metrics are actually better and it's all been done before. I don't give two ishts about whether the oil gums up at sub zero temps. A) Because I don't live or operate my car in those conditions and B) Most people using performance cars aren't worried about cold viscosity performance, they're worried about high temp performance.It's purple and meets or exceeds factory specs like almost every oil.
I have been using the Ford recommended Motorcraft synthetic blend the GT500.
My F150 with a 5.0 get's the same + Ceratec.
I like Amsoil products. But too pricey for my annual oil change. I only put about 2k a year on each vehicle.
These 2 oils take top honors in actual performance tests. I like this guy and his testing methods on all kinds of stuff.
https://www.google.com/search?q=mot...ate=ive&vld=cid:e358db0d,vid:TWuKvnCq1js,st:0
SUCKFill in the blank.
Oil threads ____
It’s a joke. I don’t know if it still says on the bottle, but it used to say that it actually added horsepower. Oil will not add or create hp, it might could free up 1 or 2 if it is slick enough but nothing anyone would notice. In my 350, I still run motorcraft 5w50. I don’t know if mobile or anything is necessarily better, but I know it’s not bad. Otherwise I was always a castrol personGoing to change oil again soon. My neighbor asked me why I use Royal Purple Synthetic? I have been using Royal Purple for quite a few years. But, I couldn't remember why. Will someone help me with a good response?
It's marketing gimmicks, but make no mistake, the entire industrial world is seeking every efficiency possible. The new age of seeking lubricants that can remain lower viscosity but still resist shear and still provide appropriate film to protect wear is all the rage. And it makes sense, over the application of millions of motors, engines, probably billions of wearing and rotating components, even if they can eek out .1%, globally it ends up saving a lot.It’s a joke. I don’t know if it still says on the bottle, but it used to say that it actually added horsepower. Oil will not add or create hp, it might could free up 1 or 2 if it is slick enough but nothing anyone would notice. In my 350, I still run motorcraft 5w50. I don’t know if mobile or anything is necessarily better, but I know it’s not bad. Otherwise I was always a castrol person
