How close is comfort for wheel space to the front strut?
Trebor355
Morrisville pa
Rob
2018gt
What's the minimum space I can have for the front wheels to the strut
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
Wheel to strut clearance doesn't need much, not as much as tire to strut depending on how much sidewall 'bulge' is present. My guess - 1/8" should be enough and 3/16" plenty for most fitments.
FWIW, I've run tighter clearances than those on my S197 without issue (with tires mounted on max-recommended wheel widths). Not everybody would be comfortable with less than 1/16".
Norm
Trebor355
Morrisville pa
Rob
2018gt
Norm
Sounds good,thanks
Trebor355
Morrisville pa
Rob
2018gt
I have a good 1/4 of an in plus a 5mm spacer if I need it,they say 6.5 to 8 turns on the lug. What do you think?
Norm Peterson
Norm
'08 GT #85, '19 WRX
Not enough. Even one diameter's worth of full-form threads ends up being at least 10 full turns (end threads are not full-form all the way to the end).
Some food for thought . . .
Norm
NightmareMoon
2016 Mustang GT PP
5mm spacers are usually fine on stock lugs.
I wouldn't run the spacers unless you need to run them, because you're really prefer to have more thread engagement and be close to the struts than have plenty of strut clearance but very little thread engagement.
