Heated/Cooled Seats mystery
DonnieO
Donnie
2017 mustang gt cs
I'm a victim as well in my 2017. Everything worked except my driver seat heater. Looked under my passenger seat...yup mine is wrong. New one came in today. Seat heater works fine now.
tapan
Mississauga
Tapan
2017 Mustang GT Premium
UPDATE: It was the module. Installed it today and works perfectly. I feel that the fans are even more powerful/louder than before. Tested both sides heat + cool simultaneously and no issues either.
I am surprised and disappointed how widespread this issue is. Unfortunately this happened a year after my bumper to bumper warranty expired.
TOP: Old module | BOTTOM: New module
A huge shoutout to the OP @JohnDoe_5oh for sharing this with us and the impressive diagnosis! Thank you!
GT Pony
Pacific NW
I am surprised and disappointed how widespread this issue is. Unfortunately this happened a few months after my bumper to bumper warranty expired.
TOP
Was everything working normally before the warranty expired? I was under the impression that the wrong module installed during production didn't give full functionality at all, even when the car was rolled off the assembly line.
tapan
Mississauga
Tapan
Everything was working perfectly fine before warranty expired. I have owned my car for just over 4 years (I am the first owner) and didn't experience any issues with the heated/cooled seats.
tapan
Mississauga
Tapan
I am not really sure if this could be the culprit but this issue happened a couple of hours after I used the cigarette adapter to power the factory air compressor (tire inflator) for a few minutes. It could be a coincidence or related.
tapan
Mississauga
Tapan
UPDATE # 2:
I replaced the heat/cool seat module after my driver's heated seat stopped working, I don't believe the issue has been resolved completely.
The bottom part of the driver's seat (under the thighs) is working fine, but I am not feeling any heat (or the fan) in the top/back side of the driver's seat. Cooled seat function is working fine. Why would just one side work? Any ideas?
Le Mans
3181ET
Rene
550 convertible 2015
hello techies,
almost the same problem here. I bought a 2015 convertible v6 for the misses. However, the problem with the heating / cooling is on the passenger side! Driver side works fine. exactly as described before...relay clicks, fan starts blowing, then slows down. Then after 20 sec, click and nothing else no heat. tried reset, activate via Sync, does not work. Then took a picture of the module. This appears to be the "problem" unit with AA no. Then remove the large plug ... it seems that a cable is melted? It was late yesterday I need to look even closer. Could this be due to the wrong module or would repairing the cable be sufficient? Thank you very much for this great forum and your help. grt from Holland
PC_GUARD
Fl
Scott
2016 Mustang GT PP1
I have this same project on my to do list. I have the parts to fix it. I bought everything off amazon, and I do not intend to cut any wires other than the ground to splice into two.
Youd think Ford would have an electrical engineer to calculate load/amperage needs to not melt a connector or a switch etc. This problem goes back to around 07 ish in the trucks and suv's
PC_GUARD
Fl
Scott
2016 Mustang GT PP1
hello techies,
Single ground which is not adequate for the load applied. I doubt the unit is shot, or faulty, just the single ground and there needs to be two grounds
Le Mans
3181ET
Rene
Thx,
where and how do i make an extra ground ?
Le Mans
3181ET
Rene
thanks man! awesome. Another question, is the extra ground sufficient or should it be replaced together with the new module ( BU5Z-14C724-A). Now the GU5T-14B663-AA is still in it. I read that the new module also controls the cooling fans better, etc.
This thread covers it
Mustang 6 thread
PC_GUARD
Fl
Scott
2016 Mustang GT PP1
I cannot answer that. I'm going on the premise the additional ground will be enough.
My seats worked great, until that happened
PC_GUARD
Fl
Scott
2016 Mustang GT PP1
I bought the pigtail AND a Delphi gm plug.
I cut the melted parts and depinned the old plug, cut the ground stripped the wire, soldered the 2 grounds and harness ground, shrink wrapped it and that's that.
No chopping up factory harness.
Le Mans
3181ET
Rene
thanks, do you have the part numbers for me?
