i dont there are unless you are dragging your bumpers on bags. most headers will give the similar power #s, its what you want to spend. cheap ones are 700-800, better ones are 1300+. if you run e85 you will have to relocate your o2s on any header but kooksAny ground clearance issues with headers? Are some brands better than others?
Mach thunder. Stanless works has a performance connect that worked for me.Which Solo performance set up do you have and did it bolt right up?
Not at all, and I'm running springs.Any ground clearance issues with headers? Are some brands better than others?
If you can't find a local place my buddy has a garage in Montgomery County, he's a Mustang guy and would probably do them for a lot less than most shops would charge.Any good shops in northeast pa? How much should i pay for la or?
Long tubes and Corsa extremes will be really loud.
1 7/8for na, what size headers you guys recommend. its gonna be paired with corsa extreme
My tests speed catted will be here tomorrow. Guy at their shop told me the power difference was like 2 hp. I don't want Nascar loud, and I m already running corsa sport cat back.Im about to pull the trigger on some Texas Speed long tube headers. Cant decide if i wanna do catted or non catted. Is the sound difference big between the two (volume and rasp)? I dont care about smells much just sound.
