Doc Holliday
So let's just say hypothetically, you do a half-second money shift coming from 60-75 and slot it in second; revs spike, rear locks up for a sec, and the clutch gets pushed back in. Would that do any kind of measurable damage?
Hypothetically speaking... yeah...
So yes, ahem...hypothetically.... doing that can cause some serious engine damage. So lets just say for a minute, again hypothetically, that you did that in your 2015 GT PP. It could cause you to throw a rod, but if that had happened, you'd already know about it because that's instant catastrophic failure. You could also damage valves and/or pistons if you had contact between the two. Valve springs could break. Cam followers can pop out of place. There are other damages that can occur as well, but these would be the more common things. If this hypothetical situation were to occur, and you really wanted to reassure yourself, you could have compression and leak-down testing done on all the cylinders, and remove the cam covers for visual inspection of the valvetrain.
Now that said, doing said hypothetical mis-shift does not 100% guarantee that you will have engine damage. The quicker you recognize it and correct it, the less likely it is to do damage. I'll admit that I did something similar once on the strip with my GT500. Luckly, I realized what had happened almost immediately and quickly depressed the clutch. It ran fine then and has ever since. I didn't do any leak-down testing or compression testing. I consider myself lucky with that one.
