GT strut tower brace installed
Mustang_Eh
Canada
2019 GT PP2
Hello all,
Figured I'd post about my experience with the GT strut tower brace on my V6. In my opinion it's not worth it and I would wait until a proper brace is made for V6. Here is why:
- Clearance - as is, the brace does not clear our intake manifold. After the adjustments below, the brace is still in contact with the manifold in the back part of the brace. Apparently out engine dips downwards under load so my friends say it's fine, but I'm not comfortable with that.
- Tower bolts (where the brace is secured) - you have to use spacers (found at a local hardware store) to raise the brace up in order to clear the intake manifold. I ran out of thread on the bolts when the brace "cleared" the manifold.
- Nuts - our cars only come with nuts on one side of the car. I bought the brace as is off some guy locally, so I do not know whether it comes with bolts or not. Another local club member told me he was not able to find these nuts at a hardware store so he paid $10 at Ford dealer to buy 2 nuts....that's nuts :cheers: I lucked out and got the 2 nuts off another club member with a PP GT that recently installed a blower so he can't use his brace (so ask around if you know other Mustang people with PP)
Point of this post: In my opinion it's not worth installing the GT brace simply because it sits so high up the bolt thread it practically eliminates the purpose of the brace, not to mention that it's still in contact with the manifold. Sure, you could modify the brace and shave it off where it still touches the manifold or leave it as is just for show, but it's not worth the money.
I'll post pics later.
Bonus: my pedals vibrate a lot ever since I put the brace on. It's weird.
Mustang_Eh
Canada
2019 GT PP2
scooter550
Phoenix
2016 V6 Mustang in Comp Orange
THANKS for an honest review.
Clarkson
Victoria
Clarkson
2017 Mustang V6 Ingot Silver Manual
Maybe just get k brace
jburgess1379
Gambrills, MD
Boosted v6
You should get the K brace with this any way. Or just the K. I have yhe the GT tower brace and K brace. No issues whatsoever. Everything clears and works fine.
Edit: I'm using washers between the 2 of course. Works great. Plenty of thread for the nuts too.
DR_
In a van down by the river
David
like a complete jerk
Absolutely should pair with the K brace.
fordguys550
yep..."just" a V6
tehachapi, ca
2016 v6 6spd
I have a vert v6 rental right now and it has the k brace. I should atleast install that on mine. All mustangs should have come with atleast that
Fuse
États-Unis d'Amérique
2016 Mustang V6
Just a few pictures of the spacers used when I installed my strut brace and cowl brace.
It doesn't look like there is space but there is actually space between the top of the intake manifold and bottom of the strut brace. I installed this Dec 2016 with about 5566.7mi and currently have 16772.9mi. I've driven over bumps and pot holes. It has stayed on and I have not needed to re-tighten or make adjustments. I've tried shaking the bar and it is solidly on there.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
With just those small washers underneath, the brace isn't doing a ton, and is putting bending loads into the studs. You would need to have a piece that has the same contact area as the tower would to take the bending load off (keep it in tension) and adequately change the load path and stiffen the front end. A machined C shape plate the thickness of the washers you used would work.
Nagare
Ft Lauderdale
2017 Lightning Blue V6
So uh [MENTION=6944]zackmd1[/MENTION]...how's that for a quick project? :shrug:
[MENTION=10281]BmacIL[/MENTION] would that be more of "extension" to the STB or to the cowl brace? Just thinking because if it matches up to the cowl brace shape it should still push through better, correct?
Fuse
2016 Mustang V6
Well I guess the more direct thing to do is lower the engine. BMR has those motor mount brackets which they say work with the stock motor mounts. I might try those over adjustable motor mounts.
DANA44
Central Connecticut
2016 v6 convertible
I added the cross brace to my vert that came with the factory K brace mounted to the fire wall. The used cross brace came with the a K brace also. I cut the k brace footing area and used it as a spacer stacking it on the the factory k brace. I have no clearance issues with the hood or the intake manifold.
Nagare
Ft Lauderdale
^same type of thing I was thinking since it maintains the same shape, how'd you cut it?
[MENTION=10281]BmacIL[/MENTION] do you think that would work just as well to get rid of the bending load?
BmacIL
Enginerd
Naperville, IL
Yes that would work much better.
