GT PP Brembo Brakes on V6
MoralesPR
Puerto Rico
2015 Mustang V6, Guard
Hello guys!
I wanted to know if the GT PP Brembos front rotors and calipers are a direct bolt on for our V6? I already changed the wheels for some 20's so regarding spacing there should be no problem.
Thanks!
DR_
In a van down by the river
David
like a complete jerk
Yes they are a direct bolt if you get the brake lines as well however IMO they are overkill unless you track. The regular GT brakes (non-Brembo) work great and are a fraction of the cost of the Brembo setup. Shelby America has takeoffs of both on eBay and the Brembos typically go for ~$700 vs ~$200 for the non-Brembos.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Agreed and honestly since the V6 is 200 lbs lighter, the base GT 4 pistons are plenty, even for track use. A better pad would be needed for that.
Drugdealr
LOLKBYE
Houston, TX
Sal
2021 Ford Mustang GT
They are direct bolt on. I have a set myself. if you go Brembo, go for ceramic pads, OEM pads are squeaky as hell.
DaZ
Greensboro, NC
2015 Mustang V6
Sorry to bump an old thread but I thought it made sense to keep a similar topic in the same thread.
I have a 2015 V6 base but I do have the 20” foundry wheels. I found a great deal on the 6 pot Brembos. Other than 15” rotors, pads and lines, is anything else needed? Not sure if things like dust covers, banjo bolts, master cylinder,etc. need to be converted as well. Any help would be greatly appreciated.
