olaosunt
I have has multiple builds with the every version of the 5.2 /Voodoo/predator and have only had one sleeved .-the original voodoo in my GT 350 after bending a rod causing the piston to damage the linerAnything specific to look out for or be aware of if using a Gen2 Voodoo 5.2 liter block for a 5.2 liter Coyote build? Would it have any strength benefit over a Gen 3 Coyote block bored and sleeved for a 5.2 build? I’m assuming It will require a Predator 5.2 crankshaft either way to achieve the 5.2 liters. It will be going In a 2019-20 Mustang GT and will be getting a mid mount twin turbo set up with a 10r80 trans. I’ve seen several used Voodoo blocks in the $700-800 range that would require sleeves in order to be used.
Just wanted to see if there is a strength benefit with a sleeved 5.2 Voodoo block verses a sleeved 5.2 gen3 Coyote block.
1250+ rwhp goal
Thanks
Ken
it was either that it a new block and a the time sleeving the old block was a cheaper option
but to answer your question the word is a sleeved predator block is the strongest block option out there not counting the Baer/werewolf iron block .
some info from RPG Instagram
