Sorry, but I'm easily confused. Why is Safelite involved if it's OEM glass?
Im still confused. Why is Safelite recalling OEM glass...?
So exactly why is the Safelite glass being recalled? Some are saying it’s the OEM Ford Carlite glass, but it’s being referred to as Safelite… and installed by Safelite.
Can we get some clarity on here? The “letter” posted in the multiple threads on here now by the OP doesn’t give any insight to the “why” nor does it say that there is a safety concern….
So does the issue extend back to any Ford Carlite glass as installed on the assembly line? Or only “replacement” Carlite that is installed AFTER the vehicle has been sold and the original is damaged?
Clarity anyone?
The OP doesn't state a reason.
I do see any reasons stated by @TEAsGrabber (OP) that would explain the recall. The safety features mentioned here (or most of them)
I believe are actually mounted in the bumper (which is the reason why Mach 1 does not have an adaptive cruise control).
So no one has yet to answer WHY is the glass being recalled?I still want to know why they are being recalled.
There’s not one mention of WHY the glass
Is being recalled in the OP’s posts per the “letter”. YES it says there is a recall, YES it says don’t rely on your safety equipment, and YES the owner has to check the stamping on their windshield to determine eligibility for the recall.
but there isn’t any reason given as to WHY the glass is being called.
Is it made of candy glass like stunt drivers and movie sets use?
Is it not clear and has defective waves in it?
Will it break into large sections severing limbs and heads instead of busting up into teeny tiny pieces like it should normally?
Does it have auto tint features where it goes black in direct sunlight?
Was it sourced from bad actors and it has tracking ability designed into it so all the tin foil hat wearers will have to pop it out of their vehicle like when they disconnect their vehicle modems, but continue to post on here using devices and ISP’s that are totally traceable?
WHY is this glass being recalled?
