Full-Race Twinscroll EcoBoost Turbo Manifold and Kit
Status
Not open for further replies.
Full-Race Geoff
Full-Race Geoff
Phoenix, AZ
www.full-race.com
Geoff
2015 Mustang EcoBoost
we have some info in the ecoboost article on our site, the photo below clearly shows the flow paths:
To answer your question, you are completely correct. The port angle visually appears different but has comparable flow paths. The reason is our cyl 2/3 cross sections are taken at the flat of the cyl head. the cyl 1/4 cross section visually appears to larger from the merge angle (dictated by the casting). Overall they are pretty close - but there is definite gains from head porting, particularly behind the valves. Our turbo kit benefits from proper head prep but certainly not mandatory. we still have the 100% oem original motor in our car
Edkiefer
NYC
XR4ti
Thanks, that is what I thought but as I have not seen disassembled engine I asked.
Yeh, that's common on 4 cylinder heads were the outlet is center, so center ports goes straight out verse ends which are angled.
Anyway, thanks for explaining/confirming :)
Your kit looks good.
Genxer
2015 Mustang GT / Perf pack / DIB
Inconel, wow! That's serious stuff.
Have you guys ever considered ceramic coating components?
WhiteyDog
WOOF!!!
Manheim, Pa.
'16 GT PP
Holy sh*t, Inconel isn't the easiest material to work with, by far. You guys did a nice job there. D*mn, you guys make stuff for the GT's?
RubyRed15
Ok, so it's blue.
CO
Ecoboost Premium PP
Below is the dyno result from the cobb accessport tune from jeff evans at evans-tuning in PA. This represents an entirely stock vehicle with our turbokit, intercooler and exhaust.
Which turbo was used here?
Full-Race Geoff
Full-Race Geoff
Phoenix, AZ
www.full-race.com
Geoff
The 5.0L GT hasn't seen any love from us yet. Our contracts with Ford are all based on EcoBoost product development: 3.5L F150, 2.0L ST/fusion, 2.3L Mustang / RS and 2017+ Raptor. Inconel 625 has a learning curve, but the benefits for this 2.3L ecoboost outweigh any other considerations. This engine can see more than 1000C EGT and will be subject to serious abuse.
Great idea and Yes, we have an entire ceramic coating operation in-house. Many of our customers order the manifolds, turbo housings, downpipes with high temp ceramic coatings. highly recommended to do this if you live near a corrosive coastal environment
Any word on price?
Complete kits are $3000 + turbo (turbo price dependant on size). If you already have an intercooler it will save approx $700
EFR7670, one of my all time favorite turbochargers.
Which fuel was used?
we tuned on 91 octane pump and 100 octane pump. (the love's truck stop gas station by our shop sells 100 oct unleaded at the pump)
Edkiefer
NYC
XR4ti
Wow , these run hot, figure it would be hotter than past OEM turbo's with fast spool up but I always remember we would try an stay below 1400F EGT on port injected engines.
Ok, but on that graph, was it 91 or 100 octane, I assume its 100 from power levels.
Edit: Ah, I see there's two graphs in there.
Full-Race Geoff
Full-Race Geoff
Phoenix, AZ
www.full-race.com
Geoff
Are these kits CARB legal?
Our kits can retain the OEM cat and satisfy certain states emissions requirements. However California is one state that does not allow the linear distance from exhaust valve to cat inlet to change - so we do not carry CARB approval
Wow , these run hot, figure it would be hotter than past OEM turbo's with fast spool up but I always remember we would try an stay below 1400F EGT on port injected engines. Ok, but on that graph, was it 91 or 100 octane, I assume its 100 from power levels. Edit: Ah, I see there's two graphs in there.
exactly, these ecoboost engines can reach astronomical exhaust gas temps. I consider 950C (1742F) to be the safe max exhaust temp - and with proper tuning you should never go beyond that. OEM tunes can get up to 1000C for emissions and fuel economy (lean burn) purposes
How about a full Inconel exhaust? :p
total waste of inconel. This material is very expensive and it's advantages are pre-turbine
ngiotta
California
2019 GT / 1970 Mach 1 (Twin Turbo Coyote)
Bummer. Over half the Mustangs sold in California are EcoBoost models and California sells a LOT of Mustangs. You guys would make a killing.
Status
