Front Control Arm Spherical Caster Bushings Ready To Ship
Hotpart.com
San Luis Obispo, CA
2002, 2006, 2015 Mustangs
J&M Products/hotpart.com has designed a new Spherical Bushing Part # 24410 for the 2015-2018 S550 Mustang GT, EcoBoost, GT350 and GT350R. Testing indicates that under track use the factory soft rubber bushings have a frightful degree of deflection. J&M’s Spherical Bushing eliminates the toe and caster alignment altering bushing deviation, and provides smooth predictable suspension articulation under the most demanding competitive on track experiences.
The largest in the industry 1 inch spherical bearings are made from 52100 heat treated steel/hard chrome plated ball; the bearing race is heat treated high strength steel with a load rating of 70,820 psi when most others are rated at 48,000 psi. The bearing liner is not the typical PTFE liner but made from a thin sintered bronze wire net impregnated with PTFE powder giving it great load capacity and longer wear; this is the same liner material that is used in modern ball joints for a maintenance free long life.
FEATURES:
  • Available in clear, red and black anodized
  • A press is required to remove the factory bushing and install the new one
  • Provides vastly improved handling characteristics
  • Will not flex under load
  • Bearing liner is attached with a thin sintered bronze wire net impregnated with PTFE powder, same as modern ball joints.
  • 52100 heat treated steel/hard chrome plated ball
  • Largest in the industry 1″ spherical bearing
Tuxedomouse
Cinci, OH
17 GT Grabber Blue Premium PP
Do these come with any adapter to remove the factory bushing or push in this bearing with a press?
shogun32
Northern VA
smooth predictable suspension gesticulation
I don't want to know what my suspension is trying to convey to me while gesticulating, but perhaps it's working great when it's articulating?
Oops, sorry to necro-thread.
VictorH
South Carolina
Victor
2021 Mach 1
Installed a set this week. The J&M control arm bearing is a quality part. Removal of the stock bushings is a little challenging.. One bushing pressed out fine, the other one mushroomed and I had to take to machine shop. The interference fit with the new parts is really tight with the arm. I don't think you need the snap rings. Overall, very happy, quality part that is superior to the OEM bushing.
