Ford Performance Lowerings Springs on GT350
dwalker
East TN
2017 GT350 white with blue stripes "H1807"
Did you use caster/camber plates or can we run these springs without them?
I’m not running plates myself. With this slight drop it’s not totally necessary in my opinion, you’ll really only gain just a little bit of negative camber. But it’s always good practice to have the alignment at least checked after any suspension changes.
Sammyd
Mckinney
1989 5.0 COUPE
Thanks for the info sir. I appreciate it.
raiderjatt02
Bay Area, CA
Jessie
2016 GT350 - Track Pack; 1995 GT - Saleen Clone
which springs will lower the R the most? i've heard the steeda ones only drop it about 1/4"? not worth it if so.
I think the Eibachs have the most drop. I've heard that they end up rubbing a little during very hard turns (like on track) so I personally wouldn't want to do it to an R. Seems like a downgrade in performance. In my opinion, BMR or FP would be the best even though the drop isn't that much.
Niz55
Us
17 GT350
Whatever you do stay away from the eibachs on your R.
Leave your car stock suspension wise. Nothing comes close to R handling.
I have had the eibachs and they were "ok" but absolutely not for track. They ride softer than stock springs as they have lower spring rate and the car floats alot more. The drop is excellent but the ride is sloppy. You will get tons more bump steer and tramlining.
They are only for looks and that's it.
I am in the process of installing KW clubsport 3 way adjustable coilovers.
hiiammarcin
Alabama
2017 GT350R
N
Did you ever get the KWs installed? Any feedback?
V8 Voodoo
Wisconsin
2021 F-150 XLT 5.0 V8
Ford Performance springs with stock wheels and tires....
Then with R spec wheels and stock tires...
When you swapped to R spec rims with the lowering springs, did you need to install adjustable end links or anything? Or did you just bolt the R spec wheels on and you were good to go? I like the look of the 11.5" tire in the back, but don't want any rubbing problems with the FP lowering springs.
wtb6mtv8rwd
California
Kevin
SOLD
Anyone get an uneven rake with those springs?
I installed those on my PP2 (for which they are advertised as compatible). The front came down nicely about half an inch. The rear barely moved. Parts numbers and installation are all correct. All suspension joints were loosened and retorqued with the car on ground to eliminate any bushing preload.
I'm stumped as everyone seems to have a nice level ride height but I have stink bug look with the ass up. Frustrating!
mavisky
Cumming, GA
Kyle
2018 GT350
Ford sells a specific set for the PP2 vehicles I believe that is a separate part number than the GT350. Can't speak to why that's an issue, but it may be related. Claims it uses the same springs, but perhaps it's an issue with the shock reprogramming somehow? Not really sure what to say.
https://performanceparts.ford.com/part/M-9602-M
wtb6mtv8rwd
California
Kevin
SOLD
Confirmed with Ford they are the same M-5300-W springs; and shock calibration wouldn't affect physical ride height.
mavisky
Cumming, GA
Kyle
2018 GT350
I couldn't imagine it would either, but physically that's the only other issue.
My only thought process is the installation method. If the springs were installed by lowering the lower control arm and that was then re-torqued with the arm in the air with no weight on the bushings, they may be binding enough to keep the car from achieving it's normal static ride height.
I installed mine by dropping the entire rear cradle vs the control arm method and my car sits perfectly.
dwalker
East TN
Nope I didn’t swap anything else, just bolted them right up. Don’t have any rubbing issues at all.
V8 Voodoo
Wisconsin
What size and type of tires are your running up front and in the rear?
