DW 400 Fuel pump
MightyMouse95
North Carolina
Steven
2015 RS3
Hey, I have a 2015 Mustang with Roush Supercharger. Sunday I upgraded to ID1050x, DW 400 Fuel pump, and the spark plugs. Since then when I go to start my car it takes me 5-10 to get it to start. It just cranks while fuel pressure builds up in the lines. I called DW they said it’s a bad check valve, get a new one installed today and it’s doing the same thing. I can’t see 2 pumps in a row being a bad check valve, any other ideas what’s wrong?
Video of it.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
So when you press the clutch, can you hear the pump prime & shut off ?
JakeLethal
Wellington, FL
Jake
2022 F-150 RCSB 5.0
Video of it.
Check valves that are starting to fail will vibrate or make a noise indicating that the valve has broken. A strange noise can also be a sign of 'water hammer' which is a high-pressure surge that occurs when the fluid comes to a stop or changes direction, often causing the disc to slam into the valve. Do you recognize an odd noise?
MightyMouse95
MightyMouse95
North Carolina
Steven
2015 RS3
Not really, this is the 2nd pump I’ve installed in a week. Same issue.
WildHorse
N/A or GO HOME
'17 S550
Fuel pump is doing it's thing. Log the startup. Send it to your tuner.
WildHorse
N/A or GO HOME
'17 S550
I did, they couldn’t find anything wrong
Really ? That's odd. Cause it is taking a while to crank. I ask em to check how much timing retard there is on the start up.
MightyMouse95
MightyMouse95
North Carolina
Steven
2015 RS3
It’s being tuned by Lund, I highly doubt they are to blame, they are very reputable
MightyMouse95
MightyMouse95
North Carolina
Steven
2015 RS3
Also the time varies, if the car is on an incline where the front end is higher, it starts a lot quicker. Doesn’t seem tune related to me.
WildHorse
N/A or GO HOME
'17 S550
Well now haha. According to DW " • Note - pump does not have an integrated check valve"
