what issues are you having? My car is currently at hpp getting some things done. Half shafts, drive shaft, and clutch will be my next mods. I just want to make sure I do everything right on this go around. I've spent a fortune trying to get the car running right with the procharger and I don't want to do the same with the drivetrain.I would go with DSS. I have had issues with Ford Racing shafts so far.
His thread about it was here: http://www.mustang6g.com/forums/showthread.php?t=18948what issues are you having? My car is currently at hpp getting some things done. Half shafts, drive shaft, and clutch will be my next mods. I just want to make sure I do everything right on this go around. I've spent a fortune trying to get the car running right with the procharger and I don't want to do the same with the drivetrain.
I checked my set, and they were the old ones with the coated stub ends. I put them in and I am not even worried about it. I didnt even bother increasing the torque to 80-85 on the bolts... 60 with loctite isnt going to fall out. Maybe next time I have the car in the air I will throw a hex socket on there and double check them, but it didnt even worry me enough to screw with it before install... and i certainly would not waste my time and money shipping them back just to get the bolts tightened more LOL.Charles,
Ford did request some changes to the Halfshafts that we manufacture for them.
They didn't want the black e-coat on the stubs so we now supply them un coated.
They were afraid the e-coat would contaminate the diff fluid. We continue to e-coat all our other product lines, it's just a Ford thing.
They also wanted a higher torque value on axle bolts, it used to be 60 ft lbs and is now 80-85 ft lbs.
Not sure if you got an older set or newer set but you would need to contact Ford Racing to see about getting them swapped out, they handle all of the distribution and warranty decisions.
I also wanted to say thank you for purchasing Ford Racing Half Shafts
Thank You
Chris Nichols
Gforce Engineering
That was not the issue. The locktite on the bolts was contaminated during manufacturing and Ford Racing said that it could cause the half shafts to come apart while driving. Ford advised that it was unsafe to drive with the shaft.Why did you have to send one back?
Its fine you made them pay for it... but you could have just tightened the bolts to the new spec and been done and over with it. I dont understand why you guys removed them and shipped them back for such a minor thing.
